Giúp dùm em Log 7610 với
Reading...
MCU SW version: V 7.0642.0
18-10-06
RH-51
(c)NMP
HW version: 6003
PCI version:
UEM version: 144
UPP version: 4225
RFIC version: 0205
DSP version: CN5.10
PPM version: V 7.0642.0
18-10-06
RH-51
(c)NMP.02
BT MCM version:
Production serial number: DDE722549
Product code: 0514521
Module code: 0202215
Basic production code: 0511637
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: h?????????????????????????????????????????????????
Default SN type: h?????????????????????????????????????????????????
IMEI plain: 356965015582905
IMEI spare to net: 3A 65 69 05 51 85 92 00
IMEI SV to net: 33 65 69 05 51 85 92 30 F3
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 7515206441
Phone type: RH-51, Software version: 7.0642.0, Language Pack: 02
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
Setting local mode...
Reading product code...
Product Code: 0514521
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-51\
No ini files found...
Máy bị lên treo logo NOKIA , e chạy lại Full ,h lên trắng tắt , mấy anh giúp dùm e với , hiccc
sao k ai có ý kiến vậy , máy a ơi
mang wwa nbox phang thử đi bác
backup lại, xóa rồi flash lại xem.
mang qua UFS fomat em nó cái xem sao bạn
bạn xóa flash đi chạy lại là dc dòng này ko sợ như dòng BB5 đâu mà sợ
các a ơi giúp cho e cái log này với
Getting MCU ID
MCU ID: 0x1081
FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
trước đó thì e vẫn chạy dược jo lại ko kết nối dc . các a giúp e vơi .thak all
Báo ko kết nối được mà ! kiểm tra lại cáp và chân tiếp xúc đi bạn !
