Samsung s3350 tiếng việt ok by FlashTool_E2
mới làm 1 em xong post lên chia sẻ cho ACE tay không bắt cướp :D
Tool đây và File đây
ACE gặp thì cứ múc thẳng tay nhé
ACE biết rồi đừng chém em tội nghiệp
http://nu6.upanh.com/b4.s33.d2/4de66...6.untitled.jpg
Device synchronized.
Injecting EBL-Loader (RPSI).
Injecting EBL
Boot-loader is active
EBL version: 6180_Bootloader_10.0_MKEYSKEY 10..0
Boot mode is: BB
Using: Faster CRC, Writing all blocks
Package length is 2048 - protocol: 1.16
Baud rate set to 921600
Get flash id.
CFI stage 1
Flash ID is: 220800EC
CFI stage 2
Boot process finished
Start downloading item 'CODE:catfish.fls'' from file 'C:\Users\ADMIN\AppData\Local\Temp\IFXzip~\S3353DX JK2_BSY_bin.fls''.
Sending sec-pack.
Load region 0
Use flash pre-erase.
Sending data.
WARNING: Target EBL does not support NVM handling
Sending end-pack.
Checksum OK (0xF406)
Verify OK
Process time was 3 min 41 sec.
Start downloading item 'CODE:catfish.fls'' from file 'C:\Users\ADMIN\AppData\Local\Temp\IFXzip~\S3353DX JK2_CDS_bin.fls''.
Sending sec-pack.
Load region 0
Sending data.
Sending end-pack.
Checksum OK (0x6674)
Verify OK
Process time was 2543 msec.
Start downloading item 'BOOT CORE SLB:dwdtoolsrc/bootcore/make/.output/XMM6180_EHS2AGR_CATFISH_ROU_TREVI/fls/psi_flash.fls'' from file 'C:\Users\ADMIN\AppData\Local\Temp\IFXzip~\S3353DX JK2_psi_flash.fls''.
Sending sec-pack.
Load region 0
Sending data.
Sending end-pack.
Checksum OK (0x680C)
Verify OK
Process time was 2184 msec.
Start downloading item 'CODE:temp_UI_IMAGE.fls'' from file 'C:\Users\ADMIN\AppData\Local\Temp\IFXzip~\S3353DX JK2_UI_IMAGE.fls''.
Sending sec-pack.
Load region 0
Sending data.
Sending end-pack.
Checksum OK (0xC6A7)
Verify OK
Process time was 20.3 sec.
Start downloading item 'CUST:temp_GT-S3350_OLA.dffs'' from file 'C:\Users\ADMIN\AppData\Local\Temp\IFXzip~\S3353OL AJK3_CSC.dffs''.
Sending sec-pack.
Load region 0
Sending data.
Sending end-pack.
Checksum OK (0x65F8)
Verify OK
Process time was 5 min 20 sec.
Total time was 9 min 49 sec.
Channel 1 is succesfully closed.
