cần phải như thế lắm
này thì cho em oánh dấu cái
:p Để tiền trong túi làm chi .....? :p
:DMua liều thuốc chuột , phòng khi chán đời :(
Samsung Network/Sim Unlock Code Generator/Patcher
Hello fellows!
Today we present a unified/streamlined and simple as (some words here) SIMLOCK/NetworkLock unlock code generator by stock+ team!
Mytool generates ORIGINAL unlock code without modyfying any files!(like most of unlocker program does)
or PATCHES The file directly, removing simlock without code!
Feel free to read README.NOW file and post your comments / infos here!
Download Version (1.3-GPU/Patch) With UI (as on screenshot)
Version History:
– 1.3
* Added direct patch method for Galaxy S 3 devices.
* Code optimization.
* More GFX card support added to hash cracking module.
– 1.2
* Added direct patch method for Galaxy S 2 devices (if you your code cant be generated or you dont have proper GPU, use this method – Read README.TXT before)
* Patching method confirmed working on HV 1.4+ version !
– 1.1
* Added GPU supported/not supported message
– 1.0
* Requires Windows .NET Framework v4
* Support for Galaxy S II Added
* Nice UI added
* ATI RV 7X0 card or nVidia ‘CUDA’ one (G80+) required to decrypt pass in this release. Next version will not use GPU but it will be slower. For these who dont have supported GPU, please wait.
* Warning: if generated code will not work for a first time when you are sure you typed it correctly, report it to us and stop trying, your phone will lock out after 3 unsuccessful unlock tries.
HOW TO RE-LOCK SAMSUNG GALAXY S (GT-I9000) (FOR WARRANTY PURPOSES ONLY)
After you get the Unlock code using our tool, enter: *7465625*638*#
Pop-up box will show up. Complete the first field (MCC/MNC) with the network you want your phone locked to (for example 260 03 where 226 = Poland; 03 = orange etc.) and the second field (Control Key) with the Generated Unlock Code.
After pressing OK, your phone should relock.
đây là chích dẫn từ forum xda-developers.com
GSM_Body (29-09-2012)
cũng sợ , nhưng vẫn đánh dấu
cứ 1 bên 15t 1 bên máy là không phải sợBài ca " Chết thì đền , chết lại đền là ok "
mật khấu là gì bạn
mật khấu là gì vậy
cám ơn anh đã chia sẻ!
thanks có dịp múc mạnh
học thầy không tày học ban/////////
yahoo; motbuocgianghoqn89 gmai; quangngocbk.com
chờ kèo thơm múc thử thaks a chia sẻ(a sent file cho em với yahoo dinhieumobile444)![]()
DINHHIEUMOBILE444 _ WELLCOM SỬA CHỮA ALL MOBILE
444 TRẢNG BOM-ĐỒNG NAI : 0909613891
