VolcanoBox 1.7.3 Released MTK Andriod EMMC Flash Format & CDMA Read info & more...
		http://www.gpgdragonsupport.com/ftpp...173-900_01.jpg
http://www.gpgdragonsupport.com/ftpp...173-900_02.jpg
http://www.gpgdragonsupport.com/ftpp...173-900_03.jpg
http://www.gpgdragonsupport.com/ftpp...173-900_04.jpg
EVERYDAY THAT YOU ARE WAITING IS MONEY WE ARE LOOSING! WE ARE UNSTOPABLE!
VolcanoBox 1.7.3
- World's 1st Added MTK Andriod EMMC Flash Format Address
-  Adjust MTK 6253 encryption
-  Added CDMA Read info
-  Modify to make more stable CDMA ESN/MEID Repair
- Added New Manuals (x:\Program Files\Volcano Team\VolcanoBox\Documents & Help\PDF Manual\)
-  Added CDMA Drivers (x:\Program Files\Volcano Team\VolcanoBoxDrivers\CDMA Drivers)
How to repair ESN/MEID with Volcano Box ?
-   Go to cdma tab
-   select your need model
-   select your phone diag port or rj45 interface port.
-   tick on read cdma info
-   press run
if all ok you can see meid esn model and bulid.
Like this
CDMA Reading Phone Info...
Phone Found..
Phone DATE : Jul 16 2010
Phone build 010-RD3550-....
Meid : A1111111111222
ESN = 807C51D8
CDMA Reading info finish.
Now your phone is ready to repair MEID/ESN
-   ENTER MEID HEX in meid/esn box.
-   tick on repair meid/esn
-   press run
http://www.gpgdragonsupport.com/ftpp...A%20repair.jpg
you can see all done !!
How to format Android phones ?
- Go to Mtk tab
- Select Built-in-Boot-10(v7.1216)(65xx_Android)
- Untick Auto Detect pinouts
- Tick on USBMODE
- Click on Read info
- Click on run
- When it’s say “Analysis for usb port, please insert phone usb cable”
- PLUG Mobile with NORMAL usb cable to computer port ( With boot keys if needed and make sure drivers are installed )
- When it’s read info complete. You can see at the end FORMAT ADDRESS like this
-  Format addr:0x428E8000 –format Length:0xE4200
- Now click on Format
- Click on yes
-  Now format windows will open. You have to write your mobile’s format address into format windows start address and format length. for example you have format address of your mobile this Format addr:0x428E8000 –format Length:0xE4200 which you read from readinfo just write 428E8000 into start address(hex) box and write E4200 in format length(hex) box. Keep in mind you don’t have to write “0x” for example if you see in log by reading info Format addr:0x428E8000 –format Length:0xE4200 then you just write 428E8000 this do not write complete address with “0x” just leave “0x” and write rest all
- After writing Format address ( without “0x” ) Click on CUSTOMIZE
- Please wait till software says Flash Erasing Complete !!
- Now check your phone if after format phone ask you for code please turn it off and check is there mmc or sim inside or not. If sim or mmc inside please takeout and power on your phone it will not ask you for code again. If sim and mcc not inside please insert it and power on your phone it will not ask you for code again.
- Your phone is done. Make sure you Read Full flash file as back for Emergency. If some thing happen bad you can write back your readed flash file so your phone will come back to previous state !!
World's 1st Added MTK Andriod EMMC Flash Format Done !!
Click here to download VolcanoBox 1.7.3 Full Installer
Click here to download Link Updated !!
