05/02/13 : UCT Plus v5.85 Released - More Than 15 New CPU Supported For MTK, SPD, Si
--------========= UCT Plus v5.85 Released =========-----------
MTK6515, MTK6236, MTK6575, MTK6573, MTK6513, MTK6236, MTK6251, MTK6235, MTK6251
SPD SC6800H, SPD 6803, SPD SC6600L, SPD WT6226, SPD SC6820, SPD SC8810, SPD 6610 SPD 6620, SPD 6600L, SPD WT6226, SPD SC6530A
SILabs
* More...
UCT Plus v5.85 Release Details:
MediaTeK (MTK):- [MTK] Add CPU 6515 Smart Phone Read Flash & Format
- [MTK] Add CPU 6236 Write Flash
- [MTK] Add CPU 6575 Support
- [MTK] Add CPU 6573 Support
- [MTK] Add CPU 6513 Support
- [MTK] Add CPU 6236 Support
- [MTK] Add CPU 6251 Support (USB And COM Support)
(*) Read Flash
(*) Write Flash
(*) Format
(*) Read Info
(*) IMEI Repair
- [MTK] Add CPU 6235 Support
(*) Read Info
(*) Read Flash
(*) Write Flash
(*) Format
- [MTK] Add CPU 6251 IMEI Support in COM Mode
- [MTK] Add IMEI Repair Support for MTK (Two IMEI options)
- [MTK] Fix Some BUG in MTK
- [MTK] MTK Add Auto Get Mobile Porject ID
- [MTK] Fix CPU 6575 Read Flash 1% Stop Bugs
- [MTK] Fix CPU 6250 bugs
SpreadTrum (SPD):- [SPD] Add CPU SC6800H\6803 Support Com Boot
(*) Read Flash
(*) Write Flash
(*) Read Info
(*) IMEI Repair>
(*) Format
- [SPD] Add CPU SC6600L, WT6226
(*) Read Info
(*) Read Flash
(*) Write Flash
(*) Read Code
(*) Read\Write NV
- [SPD] Add CPU SC6820 / SC8810
(*) Read Flash
(*) Auto Format
(*) Write Flash
(*) Read Code
(*) IMEI Repair
- [SPD] Add SPD 6610 6620 6600L WT6226 Support USB/COM Funtion
(*) Read Flash
(*) Write Flash
(*) IMEI Repair
(*) Format
(*) Read Info
- [SPD] SC6530A CPU Support COM Function
(*) Read Flash
(*) Write Flash
(*) IMEI Repair
(*) Format
(*) Read Info
- [SPD] Add Support SPD 4 IMEI Repair without Read Back Flash
- [SPD] Remake Spreadtrum Flasher Function
- [SPD] Add new algorithm For SPD Unlock
- [SPD] Add Support Spreadtrum Android
- [SPD] Add SC6803 CPU Support
- [SPD] Fix the SPD 6803 Flash Bugs
- [SPD] SC6800H_6803 Add Toshiba New Flash Support
- [SPD] SC6800H_6803 Add MST8B08B16F Flash Support
- [SPD] SC6600L Flash Function Add 2 New Boots
- [SPD] SC6600L Format Bug Fix
MStar:- [MStar] Fix Mstar 853XB CPU Bugs
- [MStar] Fix Mstar NAND Flash Bugs
- [MStar] Mstar 8532B CPU Add
(*) Read Flash
(*) Write Flash
(*) Read Code
SI Labs:- [SI] Added New CPU Support for SI Labs
(*) Read info
(*) Read Flash
(*) Write Flash
(*) Format
Universal:- [UI] All CPU if Flash Unknow You can Set the Flash Size Read Back Flash
- [UI] All CPU Read Flah auto Save Flash File Path
- [UI] Add New Flash IC Support
UCT Box - Universal China Tool
New ET-BoX Plus : Think More!
Details: 05/02/13 : UCT Plus v5.85 Released - More Than 15 New CPU Supported For MTK, SPD, Si
