GcProKey0015 World's 1st Usb Debug Enable for All Samsung.Plan format IMEICERT & More
http://www.gpgdragonsupport.com/ftpp.../GCKEY/015.jpg
Gsm & Cdma Professional Key Team
Happy To Announce
GCProKey Update 0015
- World's 1st & Unique Solution & Only Introduced by GcProKey
- Added Samsung ENABLE USB Debug option for MOST Samsung Phones.
- How to Enable Usb Debug Option While Phone is Locked ?
- Power On Phone
- Connect Phone with Pc by Normal Usb Cable
- Install Samsung Drivers if Needed
- Open GcProKey GSMTool Version 1.0.0.0011
- Click on Scan Ports
- Select Modem Port ( of your connected Samsung Phone )
- Click on "Enable ADB"
- !!! Success !!!!.. As you see Success Written. It's SuccessFully Now Enabled Usb Debug
- What is Enable ADB is for ?
- If you want to Remove Pattern Lock without getting Lost Data. just Connect phone and Enable Usb Debug and bypass Pattern Lock
- If you want to Remove User Code without getting Lost Data. just Connect phone and Enable Usb Debug and bypass User Code
- If you want to Remove Screen Lock without getting Lost Data. just Connect phone and Enable Usb Debug and bypass Screen Lock
- Many other things can be done... Many Locks can be Bypass by this way. OR if you want to do some thing with phone with ADB commands on LOCKED phones.... This is What Solution we MADE for you.
- Added Samsung plan format imeicert handling
- Gcpro is only tool can write all samsung certificate
- Added handle samsung msl code if present in certificate file.
- Added factory unlock possible if msl code present in certificate file.
- Improved adb related task.
- Improved MTK imei repair via baseband method which fail before.
- Improved HTC read imei,write imei task..should fix DESIRE 600 imei reading issue.
- Improved samsung imei write method.
- Note:
- ENABLE ADB option is used by most samsung. i can not test all phones made by samsung.
But it should work on MOST of them. incase if your phone not worked with it,
There is no other option to enable adb if this solution fail.
- Note2:
- Imeicert in plan text format like all other tools use.you can use any other tool imei certs now for write with GCPROKEY.
All model should work 100%.
Tested on N910C,N910T,G800H,G900F,I8552,SM-G850Y etc.
- Note3:
- Read Read Read HELPFILES in HelpFile folder for all details info.
- Sample 1
- Using Version...1.0.0.0011
Selected Port VCP0 = COM11
Selected Model Samsung GSM
Selected Task SAM IMEI1
SAMSUNG IMEI REPAIR & CERT WRITE STARTED...
Searching Phone Please wait...
Phone Found Wait...
TEST MODE OK..
Model := GT-I8552
UNIQID := CKxxxx
Phone IMEI := 35xxx
MSL CODE FOUND USING IT..
MSL Autho Pass..
Update IMEI Ok..
Update IMEI2 Ok..
SKEY := 0246
QCOM(QUALCOMM) detected..
Checking imeicert...
IMEISIGN PASS..
Checking imeicert2...
IMEISIGN2 PASS..
Update Simlock Ok..
Wifi_mac := 34xxx
Wifi_mac update ok.
Update SerialNumber ok..
Fixing FTM ok..
Repairing finish.
All Finish..
!!! SUCCESS !!!!
Total Time Take...00:00:56
Log Saved
- Sample 2 Enabling Usb Debug
Selected Port ssudmdm0000 = COM39
Selected Task SAMSUNG ENABLE ADB
SAMSUNG ENABLE ADB STARTED...
Searching Phone...
Phone Found Please Wait...
Sending Loader...
BASE(SM-N900)
VER(I9300XWUGML4/I9300ODDGML4/I9300DDUGNB1/I9300XWUGML4)
HIDVER(I9300XWUGML4/I9300ODDGML4/I9300DDUGNB1/I9300XWUGML4)
MNC(24)
MCC(404)
PRD(GT-I9300RWDINS)
SN(RZ1C9192V9R)
IMEI(353743050349073)
UN(CVTF1DA877BCF6F)
PN()
CON(AT,MTP)
LOCK(NONE)
LIMIT(FALSE)
SDP(RUNTIME)
HVID(Data:196609,Cache:262145,System:327681)
USER(OWNER)##
Loader Ready..
ADB IS NOW ENABLE ENJOY...
!!! Success !!!!
All job finish..
Restart Phone Manually before doing anything...
- Sample 3
Selected Port VCP0 = COM4
Phone Found Wait...
TEST MODE OK..
Model := SM-G850Y
UNIQID := CRxxxxx
Phone IMEI := 35xxxxxx
MSL Autho Pass..
Update IMEI Ok..
SKEY := 0932
EXYNOS Type Detected..
Cert write ok..
IMEICERT PASS..
Update Simlock Ok..
Wifi_mac := F4xxxxx
Wifi_mac update ok.
Fixing FTM ok..
Repairing finish.
All Finish..
!!! SUCCESS !!!!
Total Time Take...00:01:50
DOWNLOAD LINK..
All Updates & History :
GCPro key updates history
Successful Stories
Post here your success stories with GCPro key!
Follow Us on Twitter for always Update to Date:
https://twitter.com/GPGWorld
Follow us on Facebook
https://www.facebook.com/GPGINDUSTRIESWORLD
http://www.gpgindustries.com/newslet...july-18_04.jpg
http://www.gpgdragonsupport.com/ftpp...no/volcano.jpg
