+ Reply to Thread
Kết quả 1 tới 7 của 7
Chủ đề: 2 in 1 MMC UNLOCK BOX
    Administrator saigonmobile's Avatar
    Aug 2005
    Tp.Hồ Chí Minh
    Thanks
    30
    Mặc định 2 in 1 MMC UNLOCK BOX
    This MMC 2 in 1 Unlocker which with pc and without PC to unlock your MMC card. It works �Plug & Play� no need any driver to install this MMC unlocker.
    Attention Please Read this Note:
    ALL DATA IN MMC CARD WILL LOSE. BECAUSE IT WILL FORMAT YOUR MMC CARD
    Using This 2in1 MMC unlocker, It will unlocked your MMC card and all the user DATA will lose,This MMC unlocker do not read or restore the MMC password it will Format your MMC card.
    How To Unlock Without Using PC:
    Only 3 Step to unlock your MMC card without PC
    Connect the usb power to the box and u will see the RED LED will light up on top.
    Insert the locked MMC card to the �Without PC� Slot and wait 2 seconds.
    The Green LIGHT below will blinking fast (Your Card Is Unlocked).
    Note:
    If the RED LED is blinking slow and constant this mean your MMC Card is not recognized or do not have locked with password.Make sure that you are pressing the MMC card deep enough in to the �Without PC � slot. It will not works if you slot your MMC card to the �PC Unlock� slot.
    Since at the end of the slot is the switch which to activate the MMC Unlocker to unlock the MMC card.Also Make sure that your MMC card connection are Clean enough.Always Make sure the RED LED must light up before you proceed.
    How To Unlock With PC:
    Connect The box to your PC with LPT cable (25DB)
    Connect The Usb cable to the box and you will see the RED LED will Light up on top
    Run the installer �LPT MMC Unlocker Setup�
    After finish setup run the �MMC Programer�
    Insert Locked MMC Card to the slot �PC Unlock (Do not insert to the �Without PC� Slot)
    Click Unlock & Erase it will show �Initializing... MMC�
    After Few seconds it will show as below
    Sending Command 1
    RESPONSE WAS GOOD
    MMC INITIALIZED AND SET TO SPI MODE PROPERLY.
    CMD16 WAS SEND
    CMD42 WAS SEND
    DONE! CARD SEEMS TO BE UNLOCKED AND
    ERASED!
    Package Contain:
    1 X 2 in 1 MMC Unlocker
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    SỐ 693 ĐƯỜNG 3 THÁNG 2 - P.6 -Q.10 TP.HCM
    ĐT/FAX :08.3.9572152 - 08.3.8575707
    Email : support@saigonmobile.vn
    Thành viên mới TuanAnhMobile's Avatar
    Nov 2005
    Thanks
    Em cũng mua 1 cái roài thấy test okie ! nhưng 28$ anh à hơi đắt !
    Thành viên mới atu2000's Avatar
    Mar 2008
    Thanks
    cái này công năng nó làm là gì vây các huynh?
    Thành viên tích cực newmobile86's Avatar
    Apr 2008
    đồng tháp lạc đến An giang
    Thanks
    105
    CHIA SẼ,GIÚP ĐỠ VÀ CẦN ANH EM GIÚP ĐỠ,THANKS ALL
    Thành viên mới Vinamobile's Avatar
    Oct 2008
    Thanks
    Ai rành tiếng Anh dịch hộ em bài viết Unlock MMC nhé.Em mù tịt chẳng hiểu gì cả.Mà thiết bị này mua ở đâu vậy các Bác.
    V.I.P htv1810's Avatar
    Aug 2006
    Thanks
    57
    Liên hệ với admin (nick yahoo:LeHuynhXuan),Bài post đã lâu,close topic ở đây.
    Nhận unlock,sữa chữa DTDĐ và đào tạo học viên.
    AzSoft Mobile Service
    6F' Nguyễn Thị Tần P2.Q8.TPHCM
    Phone08.6124225
    Mobile-Phone0909.510312
    Thành viên chính thức hoang_tuan968's Avatar
    Apr 2006
    Thanks
    42
    Em có cái sài rất ổn mới 80% đang bí chút tiền muốn bán, bác nào cần liên hệ: hoang_tuan968
+ Reply to Thread
  1. 6010 hao pin
    By 11111 in forum DCT4
    Trả lời: 25
    Bài viết cuối: 20-04-2010, 08:25 AM
  2. Cruise !
    By haithong in forum SONY-ERICSSON
    Trả lời: 25
    Bài viết cuối: 10-11-2006, 04:40 PM
  3. 4rum có 25 thành viên mà đến những 4 MOD
    By haiminhk15 in forum Đóng góp ý kiến
    Bài viết cuối: 21-10-2006, 10:11 AM
  4. Here Test point new!
    By xiayu in forum SIEMENS - BENQ
    Bài viết cuối: 03-06-2006, 11:18 AM
  5. Trả lời: 9
    Bài viết cuối: 10-12-2005, 03:23 PM
