Kết quả 1 tới 2 của 2
rap_3g w450 máy nuoc ngoài cần ae... 04-07-2010, 08:30
TuấnPhát_GSM Lấy Smart clip làm đi anh. ... 04-07-2010, 15:48
    Thành viên chính thức rap_3g's Avatar
    Nov 2008
    Mặc định w450 máy nuoc ngoài cần ae giúp
    em mới nhân cây w450 mới gui từ nước ngoài về lúc mơ máy lên máy báo contact service center vay là sao ha ae nhơ ae giúp em cam ơn
    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    W156, W160, W161, W175, W177, W180, W230, W270, W360, W388, W396, W450, ZN200
    For unlock purposes the models W156, W160, W161, W175, W177, W180, W181, W230, W270, W360, W388, W450, ZN200 require to be connected to PC USB port.
    Connect S-Card and Mini USB data cable to PC USB port and launch SmartMoto.
    Select "Computer COM ports" in Phone connection area.
    Log to the tab "Compal models"
    Choose an appropriate model from the list.
    Press Unlock button.
    SmartMoto will inform "Connect phone to computer USB port before proceeding".
    Connect data cable to the powered OFF phone with inserted battery.
    The SmartMoto will automatically (no user intervention is required during the installation) install "Locosto flash interface" driver and display the following message: "reconnect phone and try again".
    Disconnect data cable from the phone, remove and insert the battery back to the phone.
    Connect data cable and press Unlock again.
    The unlock process continues.
    Message "Unlock ok" informs that process is finished and the phone can be disconnected.
    NOTE
    For unlock purposes the only driver that is required is the "Locosto flash interface" driver. No need to install the phone W156, W160, W175, W180, W230, W270, W360, W388 model driver.
  1. Unclock samsmung W450 và W390
    By trunghienkg in forum QUALCOMM Models (3G)
    Bài viết cuối: 24-05-2011, 12:43
  2. unlock samsung anycall w450
    By razrtho in forum Phần mềm Samsung
    Bài viết cuối: 16-09-2010, 11:37
  3. E71 rớt nuoc hao pin cần giúp!
    By kvmobile in forum BB5
    Bài viết cuối: 01-12-2009, 12:00
  4. Ghep sim 8 chân may nuoc ngoài mang về
    By ocbu in forum CÁC LOẠI ĐIỆN THOẠI KHÁC
    Bài viết cuối: 20-07-2009, 12:12
  5. Giup em mo mang W450 va W490
    By tymin20052005_tv in forum Acer - ODM - Old models
    Bài viết cuối: 01-01-2009, 08:55
