Kết quả 1 tới 9 của 9
    Thành viên chính thức 59phanboichaudalat's Avatar
    Jan 2009
    Mặc định ATF repai emmc A820l ok
    eMMC Test Point Connection Module
    1. DO NOT USE THE PHONE"S BATTERY
    2. Connect the Soldered TP Connections to ATF Box
    3. Disconnect the USB Cable and Wait until the
    the ATF Software will tell you to Connect the USB.
    Interface Reset OK!
    eMMC Access Type: SECTOR MODE
    eMMC Supported Voltage Range:
    3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
    3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
    CID : 1501004B594C30304D1235E50024
    CSD : D02701320F5903FFF6DBFFEF8A404067
    eMMC Boot Information
    Revision 1.5 (for MMC v4.41)
    BOOT PARTITION : NOT BOOT ENABLED
    PARTITION ACCESS : R/W USER PARTITION
    PERM_BOOT_CFG_PROT : DISABLED
    PWR_BOOT_CFG_PROT : DISABLED
    BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
    RESET BUS WIDTH : ENABLED
    eMMC FirmW UPDATE : DISABLED
    EMMC CACHE SIZE : 0 KB
    SUPER PAGE SIZE : 3584 KB
    HC ERASE GROUP SIZE: 512 KB
    USER AREA SIZE : 15758000128 BYTES
    BOOT PARTITION SIZE: 512 KB
    RPMB PARTITION SIZE: 128 KB
    eMMC Device Information
    Manufacturer ID: SAMSUNG
    Device Type : Embedded BGA
    Application ID : 00
    Product Name : KYL00M
    Product Rev : 1.2
    Product SN : 35E50024
    Manufactured : January 2011
    Card Specific Data
    CSD_STRUCTURE : Extended
    SPEC_VERS : Version 4.1/4.2/4.3
    TAAC : 13 ns
    TRANS_SPEED : 4000000 KHz
    READ_BL_LEN : 512 Bytes
    C_SIZE : HIGH CAPACITY
    WP_GRP_ENABLE : YES
    WRITE_BL_LEN : 512 Bytes
    CONTENT_PROT_APP : NO
    PERM_WRITE_PROTECT: NO
    TMP_WRITE_PROTECT : NO
    Extended CSD Saved:
    1501004B594C30304D1235E50024_5995F0D9.ext_csd
    Backup Directory:
    C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
    Start Writing 0x00100000 Blocks at 0x00000000
    Partition Selected: USER AREA
    Total Elapsed Time 00:15:59
    Write Success!
    anh em gặp mạnh tay múc
    từ beer 333 qua tiger
    alo:0937389996
  2. ( 59phanboichaudalat ) đã được 8 thành viên cám ơn vì bài viết hữu ích!
    bl0gmobile (24-02-2015), CAM KHE GSM™ (02-02-2015), damxuanquang (05-01-2015), Hoang_Khai_GSM (02-02-2015), nnm (07-01-2015), QUỐC CƯỜNG MOBILE™ (02-02-2015), thaigsm181 (11-02-2015), thanhkien90 (09-02-2015)
    Thành viên chính thức DINH_PHÁT_MOBILE™'s Avatar
    Dec 2011
    ngon nha a
    Thành viên mới zinzinlinkin's Avatar
    Apr 2011
    kèo ngon quá e cũng mới làm đc vài con 760
    Thành viên chính thức minhquang79's Avatar
    cho xin file & testpoint luôn đi bạn
    May 2014
    CẨM KHÊ-PHÚ THỌ
    up luôn pin out cho ae coi.thanks
    0985210545
    Vi phạm nội quy tuanngoc2911's Avatar
    lock đẹp ghê hế hế .....
  8. #7
    Thành viên chính thức thanhkien90's Avatar
    Dec 2009
    vĩnh phúc
    mình có 3 con a770 làm được 1 con,còn 2 con info log toàn lỗi
    thanhkien90 .call:0966552599,
  9. #8
    Thành viên chính thức thaigsm181's Avatar
    May 2012
    AN PHÚ BÌNH DƯƠNG
    Trích Được post bởi 59phanboichaudalat Xem bài viết
    Interface Reset OK!
    Application ID : 00
    Product Rev : 1.2
    Card Specific Data
    TAAC : 13 ns
    WP_GRP_ENABLE : YES
    Extended CSD Saved:
    Backup Directory:
    Write Success!
    cho em xin cái pinout , cám ơn
    www.thaimobile.tk
    call zalo 097151181
  10. #9
    Thành viên mới bl0gmobile's Avatar
    Oct 2012
    anh ơi cho em xin cái hình với đang cần .
    ai đi qua cho em xin cái hình
