Kết quả 1 tới 7 của 7
    Thành viên mới thaison434's Avatar
    Mặc định 7210c lên nokia rồi mất nguồn !
    e nhận 1 cây 7210c bật nguồn lên chữ nokia rồi treo trắng màn hình đứng máy luôn . e da read file rpl va pm 308 > xóa full>nap FW chuẩn > Write : RPL>Write : pm308 >SX4 >write pm full . vẫn không được va mxkey báo như thế này ae xem giúp e với ..
    MXKEY Serial: [FT SCR2000 0] - C085367A
    Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
    Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011)
    Processing MCU file: rm436__07.23.mcusw
    [BB5,BB5 ALGORITHM] size: 18.06 MB
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 09A0010C0EF058504D0A466D1C8EAD48FDD28585
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
    Erase size: 19.12 MB
    CMT NOR area [00000000-000006BF] erased in 0.704 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.140 s
    CMT NOR area [00040000-000BFFFF] erased in 2.875 s
    CMT NOR area [000C0000-0013FFFF] erased in 0.203 s
    CMT NOR area [00140000-0119FFFF] erased in 1 min 26.359 s
    CMT NOR area [011A0000-0133FFFF] erased in 9.094 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 (RAP Certificate 142 v.1) sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 2 min 13.157 s
    Processing PPM file: rm436__07.23.ppm_v
    [BB5,BB5 ALGORITHM] size: 7.68 MB
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 8.62 MB
    CMT NOR area [01340000-01BDFFFF] erased in 2.031 s
    Error chk C7012D0103CD000010000000F1
    RX2 not responding, please check BSI/cable/pinout !
    Error while programming [00] at 0x01AC0000, Result: 0010
    Task failed at (0800001C)!!!
    Last RX buffer: C7 01 2D 01 03 CD 00 00 10 00 00 00 F1 72
    Thành viên chính thức uongdongthanh's Avatar
    chạy ver cao nhất thử đi a
    không gì là không thể
    Thành viên kỳ cựu chanhtin_2104's Avatar
    Đến Từ TP HCM
    Thử chạy lại bằng USB xem sao nhé bạn
    .___,/ ;''|'|| I LOVE YOU |
    [,...|__|=|===_____..._...___|
    Thành viên chính thức ngoinhalatdat's Avatar
    Mar 2008
    em nay` 100% la phần mềm rui.anh cho e no' con ver cao nhất vào nhé.nếu hok đc a thử lak lại con u coi ỏn hok?
    Thành viên chính thức thanhtvmobile's Avatar
    lắc cặp lại cái bạn ơi,not ok làm chân lại cái nhà lầu đi cho vững!
    V.I.P Chaunv.Mobile's Avatar
    Tiền Giang
    Trích Được post bởi thanhtvmobile Xem bài viết
    toàn là xúi tầm bậy không. Bạn chạy lại cho nó kiếm cọng cáp chuẩn mà chạy, mới làm hôm qua 1 cây cũng y như vậy cuối cùng vào support down cho nó cái file khác chạy lại ok liền, không hiểu vì sao luôn chẳng lẽ file bị lổi. Bó tay
    Học Học Nữa Học Mãi
    Cũng tùy trường hợp thôi a Chanv.Mobile ạ!tai vấn đề này dã có a kêu chay ver cao lên,có a cũng đã góp ý chay usb rồi!vậy theo a a sẽ chạy cho tới khi nào lên thôi hả?
  1. Trả lời: 13
    Bài viết cuối: 08-11-2013, 21:51
  2. 7210c lên nokia rồi treo
    By bacquandtdd123 in forum BB5
    Trả lời: 11
    Bài viết cuối: 03-06-2012, 19:58
  3. Trả lời: 10
    Bài viết cuối: 24-12-2011, 11:59
  4. 7210c lên nokia treo máy...
    By baoduc_ayunpa in forum BB5
    Bài viết cuối: 08-08-2011, 21:47
  5. Trả lời: 7
    Bài viết cuối: 29-01-2011, 12:47
