em có con 5130 bật nguồn thì chỉ hiện treo nokia mà không sáng màn.em cho qua mx box check thì như thế này:
MXKEY Serial: [MxKey HTI FLASHER INTERFACE 5] - C0853805
Using device: HTI BOX, FW ver: 00.07
Driver: FTDIBUS, ver: 2.4.16.0 , NTMP ver: 2.0.0.1
Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1BC00113FF2A8D563FE8BD4FAACB6DB2D10B32CF
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Original Imei: 35935503305125
Original Product code: 0579020
Bluetooth ID: A87B392AAEF6
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 35935503305125-6
Product Code: 0579020
Battery voltage: 4833 mV, current: 26 mA
Language Pack:
- not available.
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
Failed to read SP data
mong các bác xem và chỉ giáo cho em biết phải làm như thế nào.em cảm ơn
