Kết quả 1 tới 8 của 8
    Thành viên mới quynhnhu mobile's Avatar
    Aug 2011
    Smile nhờ anh em xem giùm log e66
    Using device: HTI BOX, FW ver: 00.07Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]EM0 ID: 00000296EM1 ID: 00000B22PUBLIC ID: 0800010A80A80052118B47A9AFE8454A862D135FASIC MODE ID: 00ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371ROM ID: 4B9B75103E691FF8SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    TransmissionMode: DDR&TX2FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,CMT ALG [35]: XSR 1.5Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.10.0 revision: 2.0 size: 0x875B6
    TransmissionMode: DDR&TX2CMT PAPUBKEYS HASH: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93Original Imei: 35154904817154Original Product code: 0566412Bluetooth ID: 181456C0691ASIMLOCK PA identifier:
    [0] PA_SL2[1] PA_SL3
    Phone Type: RM-343 (Nokia E66)SW Version: V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia Imei plain: 35154904817154-1Product Code: 0566412Battery voltage: 4756 mV, current: 25 mAApeCoreSw: 500.21.009
    Language Pack:- not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    TimeStamp: 2011-03-24T05:57:49+00:00SW Version: 510.21.009Variant Version: 001ProductProfile:
    Simlock: Inactive_sim_bb5.bin
    Imei net: 351549048171541Version: SIMLOCK SERVERCounter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000PROFILE_BITS: 0000000000000000
    BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPENBLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPENBLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPENBLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPENBLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPENBLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPENBLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    [B]máy rớt nước mất nguồn ,em làm lên nguồn rồi mà trắng màn hình ,em đã thay dây nguồn ,màn hình ,thay khiển màn hình luôn mà vẫn vậy ,nhờ all anh em giúp đỡ thanks all.
    Aug 2011
    đây là log lash .
    Processing MCU file: rm343_510.21.009_prd.c00
    [BB5,XSR 1.5] size: 68.80 MB
    Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ALG [35]: XSR 1.5
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning ...OK
    Erase size: 122.56 MB
    CMT MuxOneNAND area [00040000-007FFFFF]
    CMT MuxOneNAND area [00A00000-0759FFFF]
    CMT MuxOneNAND area [0F1C0000-0F8BFFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 (RAP Certificate 102 v1) sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS*CORE block sent
    CMT SOS+ROFS block sent
    Programming completed in 3 min 17.328 s
    Processing PPM file: rm343_510.21.009_prd.v16
    [BB5,XSR 1.5] size: 27.14 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ALG [35]: XSR 1.5
    Erase size: 33.56 MB
    CMT MuxOneNAND area [05420000-0759FFFF]
    CMT SOS+ROFX block sent
    Programming completed in 1 min 20.625 s
    Processing CNT file: rm343_510.21.009.02U
    [BB5,XSR 1.5] size: 15.79 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ALG [35]: XSR 1.5
    Erase size: 64 KB
    Programming completed in 47.782 s
    Processing APE Variant file: RM343_ENO_0741.10_08wk42.a26.fpsx
    [BB5,XSR 1.5] size: 1.54 MB
    Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 400C192101031103, 4003192101031103, 4003192101051103, 400C192101051103
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ALG [35]: XSR 1.5
    Erase size: 64 KB
    CMT SOS*ENO block sent
    Programming completed in 4.797 s
    Total time for flashing process(boot+erase+write) was 5 min 53.296 s
    SW Version: V ICPR71_09w47.10 20-01-11 RM-343 (c) Nokia
    Battery voltage: 4801 mV, current: 22 mA
    Language Pack:
    - not available.
    SIMLOCK_TEST passed
    Counter: 0/3, 0/10
    nhờ tất cả anh em giúp đỡ
    TP.Tuy Hòa
    vô nước trở nên trắng cứ HW mà làm
    không liên quan gì SW cả
    Aug 2011
    Trích Được post bởi TUYHOA_GSM Xem bài viết
    thanks anh để em làm lại xem sao.
    V.I.P nguyenthong21's Avatar
    XU THANH
    kiểm tra tx màn remove mấy con tụ mas đi.đo trở kháng xem có chân nào mất áp không.kiểm tra luôn xem máy có nghe gọi bình thường không nghé bạn
    THẾ GIỚI DI ĐỘNG THANH THẢO
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    lên trắng màn hay trắng treo lun bạn
    yahoo: viethuy_mobi
    TP Hồ Chí Minh
    test dây nguồn màn hình not ok thì lấy sơ đồ ra kiểm tra khiển màn hình áp cấp. cuối cùng là đến ( U ) Rap.
    Thành viên mới 7l0ve's Avatar
    anh em giúp em chọn file thủ công em e66 Rm 343 với ạ .E chạy bằng HWk
  1. ae xem giùm cái log
    By boss12397 in forum BB5
    Bài viết cuối: 05-05-2012, 18:04
  2. ae hướng dẩn giùm e cách repait boot con ss s5230 giùm e với
    By truong25071990 in forum Phần mềm Samsung
    Bài viết cuối: 14-01-2012, 14:57
  3. cần anh em chỉ giùm updat model giùm
    By tranquocthangts in forum J.A.F
    Bài viết cuối: 07-06-2011, 13:06
  4. Nhờ xem giùm log
    By vvc in forum BB5
    Trả lời: 18
    Bài viết cuối: 14-08-2009, 20:44
  5. Anh em xem giùm cái log
    By ThienKim GSM™ in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 01-06-2009, 17:14
