Kết quả 1 tới 10 của 17
    Thành viên chính thức nguyendong_mobi's Avatar
    Mặc định 5530 lên chữ NOKIA trắng rồi tắt
    mình mới nhận em 5530 mở nguồn lên hiên chữ [không mở được liên hệ nơi bán hàng] cho vào hwk flash giờ mở nguồn lên chữ NOKIA trắng rồi tắt đưa qua mt nạp nhiều file vẫn not ko nhờ ae xem hộ còn đây là log của em nó thanks al411979e81e: 411979E81E - Nokia Flash/Repair v2.38.7
    Box: CR V 3.001 22752
    Code: NK V 2.001 1056
    SN: 411979E81E
    Nokia Unlimited: 114 times started
    SonyEricsson Unlimited: 0 times started
    1600 RH-64_7.02 - Installed, Auto add.
    RM-559 - Installed, Auto add.
    rm-713 - Installed, Auto add.
    RM-504 - Installed, Auto add.
    FAILED to find USB Device.
    Attach phone to usb port!
    Switched to USB BUS
    Scanning files, please wait...
    Done
    ============= Set Flash mode for info =============
    Boot...
    CONNECT PHONE to USB and Power ON phone!
    Pooling for phone...
    \\?\nmwcd#vid_0421&pid_0106&if_oth#6&36f37f01&0&00 #{4f919102-4adf-11d5-882d-00b0d02fe381}
    RAPIDOv11_2nd.fg
    RAPIDOv11_XSR15_alg.fg
    Failed to receive confirmation after CMT ALGO!
    ============= Set FBus mode for info =============
    Pins:
    Mbus 1, Box Tx 1, Box Rx 0, Bsi 0
    ERROR: Unable to open file
    C:\Documents and Settings\XP3\My Documents\RM-504_32.0.007_prd.core.C00
    Terminating flash procedure
    Boot...
    RAPIDOv11_2nd.fg
    Pins:
    Selected Highest installed version: 40.0.003
    Mcu RM-504_40.0.003_prd.core.C00
    Ppm RM-504_40.0.003_prd.rofs2.V22
    Ppm RM-504_40.0.003_C04_prd.rofs3.fpsx
    Content RM-504_32.0.007_007_000_U001.uda.fpsx
    MemoryCardContent
    5530_SW_0634766_SEAP_2G_3.0.fpsx
    Boot...
    Pins:
    Using Tx2 Data line.
    Processing File: RM-504_40.0.003_prd.core.C00
    Boot...
    Sending ULO code
    Isa UPDAPP
    RAP3NAND
    PASUBTOC
    UPDAPP
    Pooling for device removal...
    Device removed
    Pooling for ADL device...
    \\?\nmwcd#vid_0421&pid_0105&if_oth#6&1f802814&0&00 #{4f919102-4adf-11d5-882d-00b0d02fe381}
    Erase[289.87 MB]...
    erasing APE [00040000 to 00082FFF]
    erasing APE [00083400 to 003FFFFF]
    erasing APE [00400000 to 007FFFFF]
    erasing APE [00800000 to 00D5FFFF]
    erasing APE [00D60000 to 09E5FFFF]
    erasing APE [09E60000 to 0F71FFFF]
    erasing APE [07360000 to 0935FFFF]
    erasing APE [09360000 to 09E5FFFF]
    in 11.19s
    Flash[105.24 MB]...in 34.02s
    * * Processed file in 61.80 seconds
    Processing File: RM-504_32.0.007_007_000_U001.uda.fpsx
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Flash[6.13 MB]...in 1.92s
    * * Processed file in 2.05 seconds
    Processing File: RM-504_40.0.003_prd.rofs2.V22
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Flash[31.50 MB]...in 10.00s
    * * Processed file in 10.14 seconds
    Processing File: RM-504_40.0.003_C04_prd.rofs3.fpsx
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Flash[5.32 MB]...in 1.72s
    * * Processed file in 1.84 seconds
    Restarting device...
    Device disconnected.
    * * * Phone flashing done in 1:19 minutes
    Post Flash serial tunning of phone....
    Pooling mode for full factory set...
    V ICPR72_10w29_tube1/24-05-11/RM-504 (c) Nokia
    IMEI: 358307039200032
    Factory Default Settings...OK
    Dynamic camera configuration...
    Phone is in: Local mode
    Imei: 358307039200032
    358307039200032
    Backup SIMLOCK:
    C:\Program Files\GriffinTeam\MT-Box\bb5bckup\358307039200032.pm
    Section 78:
    Section 134: , 00[1], 01[2000], 03[1], 04[1], 06[1], 07[1], 09[28]
    Reading phone PM 308:1...
    Booting Phone...
    Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit
    !!! FAILED !!!
    Finished in 17s
    l
    Moderator TÚ CÒI's Avatar
    hà nội
    lỗi liên hệ nơi bán hàng là lỗi phần cứng
    nhẹ nhất là bị đường chân pin
    bạn tháo máy ra xem tình trạng thế nào
    -nếu vẫn đẹp thì làm lại phần mềm cho trở lại lỗi ban đầu rồi tính tiếp
    -nếu máy xấu thì múc cứng thôi
  3. ( TÚ CÒI ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    nguyendong_mobi (19-11-2011)
    Thành viên tích cực SỸ HẢI_mobile's Avatar
    Booting Phone...
    !!! FAILED !!!
    Finished in 17s
    Khởi động điện thoại ...
    Không hợp lệ phản hồi từ RAP3 khởi động (vấn đề cáp / điện thoại RAP3 chip / mạch điện bị hư hỏng hư hỏng
    ! Không thành công!
    Kết thúc trong 17S
    nó báo như vậy bạn thư thay cáp chạy lại ko được thì làm cứng nha
    sỹ Hải_mobile
  5. ( SỸ HẢI_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tinhh trạng máy vẫn keng ae cho thêm ý kiến thanks all
    Thành viên chính thức bonmobile89's Avatar
    Dec 2010
    loa ver cao nhất từ navifirm rùi quất bằng phoenix xem sao anh
  8. #6
    May 2011
    Hà Nội City
    Bạn có thể chạy lại bằng die usb tránh tình trạng pinout có vấn đề
    lấy ver cao nhất về múc usb đi đã bạn
    nếu dùng được phoenix thì chạy die usb cho em nó phát đã
  9. #7
    ver đó là cao nhất rồi mà nạp cả file nước ngoài luôn rồi vẫn not ok ae ai đã gặp qua chuẩn bệnh em nó giúp mình cái thanks all
  10. #8
    V.I.P minh thai's Avatar
    Trích Được post bởi ĐẶNG BẢO_GSM™ Xem bài viết
    Chung ý kiến .
    Bến Lức_Long An
    minhthai379
  11. #9
    loa file trên navi về nạp box thì được file đó đưa qua phoenix nạp nó báo file chưa đủ hay nhỏ quá gì đó. khó hiểu thật
  12. #10
    May 2011
    Hà Nội City
    đang chạy phoenix à bạn?
    nếu vậy thì bộ file của nó phải load trên navi về và phải full thì mới ok
    có gì bung yahoo mình xem cho
  13. ( ĐẶNG BẢO_GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. Trả lời: 5
  2. Trả lời: 2
    Bài viết cuối: 07-08-2013, 16:01
  3. Xin giúp nokia 5530 lên rung hepl
    By dinhhieu444 in forum BB5
    Bài viết cuối: 26-09-2012, 16:12
  4. Trả lời: 10
    Bài viết cuối: 06-08-2012, 12:26
  5. nokia 5530 lên nokia rồi tắt !!!
    By vinhbinh12a7 in forum BB5
    Trả lời: 13
    Bài viết cuối: 17-05-2012, 18:47
