lúc nhận máy tình trạng bỏ thẻ nhớ vào trắng mh và reset
đưa vào mx box đang chạy thì báo lỗi
MXKEY [FT SCR2000 0], SN: C08201DC
Using device: HTI, FW ver: 00.24, SN: 0001086B
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12923(10-10-2011)
Processing MCU file: rm36_5.050407_b5.c0r
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 20.25 MB
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200
Supported Ids: 17100701, 17100702
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: FFD729DBAAE6356AED6A1FFC1D0D6BBE1C9E0DB8
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1020010591C54F579557C855BE50FCF295A8F379
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FAC901AEE
SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
eBB5ProtocolType: OLD
Storage0: 00EC 22FA - 0000 0011 [Samsung K8S6415ETA,64 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
Storage0: 00EC 0035 - 00A5 00BD [Samsung K5E5657ACK,256 Mbits] type: FLASH,NAND, asic:APE
Storage content: 0002 0000 0006 0000 0000 0000 0000 0000
Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
Erase size: 37.34 MB
CMT FLASH,NOR area [00000000-00509139]
CMT FLASH,NOR area [006A0000-006BFFFF]
CMT FLASH,NOR area [006DF000-006EFFFF]
CMT FLASH,NOR area [00700000-007EFFFF]
erased in 1 min 0.547 s
Prog.status for Asic CMT ...
NOR: OK
NAND: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 0F72BF9D [Rap certificate3] sent
APE KEYS block sent
APE X-LOADER block sent
APE PRIMAPP block sent
APE SOS+LOADER block sent
APE SOS+XZIP block sent
APE PASUBTOC block sent
APE PAPUBKEYS: 0F72BF9D [APE certificate3] sent
APE SOS*CORE block sent
Prog.status for Asic APE ...
NOR: OK
NAND: OK
Programming completed in 1 min 30.406 s
Processing PPM file: RM36_5.050407_B5.v36
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 3.95 MB
Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200
ERROR: Phone does not respond flash config request !
Task failed at (08000008)!!!
Last RX buffer: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 5F 51 FF FF FF FF FF FF FF FF FF
bây giờ bỏ vào nbox không chét đc
nhưng bỏ vào mxbox thì nó lại như dậy
đã chạy từng file ok nhưng máy ko lên nguồn
chạy 2 file lại báo lỗi như vậy
