Kết quả 1 tới 10 của 14
    Thành viên mới tinhhue86's Avatar
    Mặc định 3110c contacservic xin anh em giúp đở , đây là log của em nó
    MXKEY [FT SCR2000 0], SN: C0858B33
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.70
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    Processing MCU file: 3110c_TV_OK.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    Waiting for USB device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 472EEA3
    CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
    CMT EM0 ID: 00000232
    CMT EM1 ID: 00000353
    CMT PUBLIC ID: 1520000850DE7E56201E951E6B655545C9DD38D8
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
    CMT ROM ID: 191EC665DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x38C0 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2D8FE542
    Verifying communication to device OK.
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.672 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.688 s
    CMT FLASH,NOR area [00020000-0007FFFF] erased in 2.125 s
    CMT FLASH,NOR area [00080000-000DFFFF] erased in 2.250 s
    CMT FLASH,NOR area [00100000-001FFFFF] erased in 5.500 s
    CMT FLASH,NOR area [00200000-0031FFFF] erased in 6.531 s
    CMT FLASH,NOR area [00320000-0105FFFF] erased in 1 min 12.859 s
    CMT FLASH,NOR area [01060000-01067FFF] erased in 0.656 s
    CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.656 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    Programming completed in 52.579 s
    Processing PPM file: 3110c_TV_OK.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    Erase size: 4.62 MB
    CMT FLASH,NOR area [01080000-0151FFFF] erased in 25.875 s
    Programming completed in 15.907 s
    Processing CNT file: 3110c_TV_OK.image_ora_pl_games_128
    [BB5,BB5 ALGORITHM] page size: 64 K size: 4.63 MB
    Erase size: 10.75 MB
    CMT FLASH,NOR area [01520000-01FDFFFF] erased in 1 min 12.235 s
    UCP page size is 128 K.
    Programming completed in 16.609 s
    Total time for flashing process(boot+erase+write) was 4 min 52.125 s
    Device connected: nmwcdc\Nokia 3110 classic USB Phonet, PORT_ID: 3332F2AB
    Phone type: RM-237 (Nokia 3110c)
    SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
    Imei plain: 35318303622486-0
    Product code: 0514949
    Battery voltage: 3572 mV, current: 107 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei net: 353183036224860
    Counter: 0/3, 0/10
    CONFIG_DATA: FFFFFFFFFFFFFFFF
    PROFILE_BITS: FFFFFFFFFFFFFFFF
    BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
    Thành viên mới xuanthanhtg's Avatar
    check xong updatesimlock cái xem thế nào a
    Trích Được post bởi 0937174066 Xem bài viết
    thử mà không được
    Thành viên chính thức mjnhtuan123's Avatar
    Nov 2010
    sx4=>repai sd.wier pm 1&309=>updatesimlock=> ok.nêu ko đươc nữa thì cho id va pass xem dùm cho
    Thành viên chính thức liveboon's Avatar
    Oct 2011
    đem qua phonenix chiển thử bạn.
    May 2011
    Hà Nội City
    Repail simlock + update simlock
    Cái này repail SD Super auth + wirte pm 1 và 309 là done
    Không được liện hệ yahoo dưới chữ ký làm giúp
    Thành viên kỳ cựu TẤN PHÚC's Avatar
    long an
    cái này chiến dể mà tool jaf crack cũng ok
    ĐTDĐ TẤN PHÚC LONG AN hotline 0986.58.78.79
    AGRIBANK 6607205041502 - CN Tân Thạnh-Long An- CTK Trần Văn Niềm
    Chuyên Sữa: Điện Thoại ,Unlock. Chạy phần mềm, nạp Tiếng Việt
    Bắc Hòa-Tân Thạnh-Long An
    Moderator VanTuan-ST's Avatar
    Nov 2007
    Sóc Trăng
    Repair SD =>Super SD Auth=>Wr pm 1 & 309 done.
    Thành viên chính thức LongBiênMobile's Avatar
    chuẩn nè => làm theo từng bước nhé !
    Tel: 0982 980 688 Y/M : long_gsm
    long an
    ok chưa bạn, sau ko thấy chủ thớt nói gì
  1. 3110c contacservic xin giúp
    By hachanyen in forum BB5
    Trả lời: 23
    Bài viết cuối: 12-10-2012, 11:09
  2. xem giúp log 6100 contacservic
    By 99999 in forum DCT4 - WD2
    Bài viết cuối: 25-06-2012, 07:33
  3. 3110c contacservic
    By moivaonghenenga in forum BB5
    Bài viết cuối: 12-04-2011, 14:45
  4. 3110c contacservic
    By nhan_chim in forum BB5
    Trả lời: 11
    Bài viết cuối: 28-11-2010, 11:26
  5. 3110c contacservic xin giúp đở
    By hoang khang in forum BB5
    Trả lời: 25
    Bài viết cuối: 24-04-2010, 21:04
