Kết quả 1 tới 10 của 12
    Thành viên chính thức vungtaumobifone's Avatar
    Mặc định xem dùm log n70
    chay phonenis ko dc chuyễn qua cáp mxkey thì nó báo như vậy ver nó 5.06 sài chậm vào wes khó đọc nên nâng lên mà nó ko chịu cũng ko hiểu tại sao nên nhờ ae chĩ dùm
    day;Phone type: RM-84 (Nokia N70)
    SW version: V 05wk07v45 29-08-06 RM-84 (c) Nokia.
    Imei plain: 35938100272406-1
    Product code: 0534652
    Battery voltage: 4814 mV, current: 83 mA
    ApeCoreSw: V 5.0638.3.0.1
    ApeVariant: V 5.0638.3.0.1-APAC1 18-09-06 RM-84 (c)Nokia
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 359381002724061
    Version: SIMLOCK SERVER VERSION 58
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Version from phone: 5.0638.3.0.1
    Version from file: 50717301.c0
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085C6B5
    Using device: HTI, FW ver: 00.24, SN: 0001608A
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
    Reading RPL backup ...
    Reading Secure Storage ...
    Reading Important data ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    APE Data :
    SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
    ASIC MODE ID: 00
    PUBLIC ID: DAE9A3DBD327B2E1F4E27CC9CDB53683F67CC04D
    ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
    EM0 ID: 00000232
    EM1 ID: 00000352
    PUBLIC ID: 0E6001077C604E51F32DCD100D7B05BD52E60440
    ASIC MODE ID: 00
    ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
    ROM ID: F28A211FCEA7B19D
    SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
    Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
    eBB5ProtocolType: OLD
    Storage0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    TransmissionMode: DDR&TX2
    SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
    Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
    Read Certificate failed.
    NPC_DATA is empty.
    SUPERDONGLE_KEY_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\BB5_3593810027240 6_BACK.rpl"
    Processing MCU file: rm84_50717301.c0
    [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB
    Supported Ids: 17100701, 17100702
    APE Data :
    ASIC MODE ID: 00
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000352
    ASIC MODE ID: 00
    BỆNH CUẢ MÁY NHƯ VÙNG SA MẠC!!!!
    KIẾN THỨC TA CHỈ LÀ HẠT CÁT...??????
    Thành viên chính thức toantkx92's Avatar
    Jun 2011
    fang 5.07 đj bạn
    Apr 2010
    xem lại cáp đi anh ơi lấy hợp khác múc đi anh
    Thành viên tích cực chanhtl's Avatar
    Jun 2011
    ĐỨC HÒA LONG AN
    nbox đi bạn mxbox dạo này chạy mấy dòng n hay điên điên đó
    nếu đang chạy mà dừng lại thì nhấp vào flash chạy tiếp ko thì bỏ qua nbox chạy ok liền
    chúc lụm lúa
    SẴN SÀNG HỌC HỎI-SẴN SÀNG CHIA SẼ
    nam định
    cho nó cái ver đụng lóc nhà vào. cái mx box chạy cà tứng lắm.không chỉ riêng dòng N mà mấy con 3110c-6300 chạy toàn báo lỗi.flash đi flash lại mấy lần mới dk.nản
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    Thành viên mới Hoang_Hai_Mobile's Avatar
    Sắm thêm ATF mà chơi . Flash sướng lắm
    vẻ cao nhất dây nó chĩ chạy 1 file MCU rồi dừng ở dây
    Version from phone: 5.0737.3.0.1
    Version from file: 50737301.c0
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35938100272406_BA CK.rpl).
    Processing MCU file: rm84_50737301.c0
    APE Data :
    ASIC MODE ID: 00
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000352
    ASIC MODE ID: 00
    Storage0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: FLASH,NAND, asic:APE
    Suggested algorithm: OMAP1610 GBBM-1.8.1 ALG
    Storage content: 0002 0000 0006 0000 0000 0000 0000 0000
    Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
    APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    Partitioning ...OK
    Erase size: 68.92 MB
    CMT FLASH,NOR area [00000000-0052B515]
    CMT FLASH,NOR area [006A0000-006BFFFF]
    CMT FLASH,NOR area [006DF000-006EFFFF]
    CMT FLASH,NOR area [00700000-007EFFFF]
    erased in 38.594 s
    Prog.status for Asic CMT ...
    NOR: OK
    NAND: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 0F72BF9D [Rap certificate3] sent
    APE KEYS block sent
    APE X-LOADER block sent
    APE PRIMAPP block sent
    APE SOS+LOADER block sent
    APE SOS+XZIP block sent
    APE PASUBTOC block sent
    APE PAPUBKEYS: 0F72BF9D [APE certificate3] sent
    APE SOS*CORE block sent
    Prog.status for Asic APE ...
    NOR: OK
    NAND: OK
    Programming completed in 1 min 54.234 s
    Processing PPM file: 50737301_RM84rd.V57
    [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 15.17 MB
    Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200
    nam định
    mang qua hwk xem sao.mx box chưa tin tưởng lắm
    nam định
    not ok kiếm dây usb mà chạy bằng phonix
    giờ nó treo máy nokia luôn phonnix lai ko nhận cápde639 minh coi lại xem cám on ae nhiều
    mình báo lai sau
  1. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  2. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  3. Anh em chỉ dùm hộp mt-box
    By trangvinh in forum MT-Box
    Trả lời: 27
    Bài viết cuối: 26-12-2012, 10:37
  4. mấy anh xem dùm em cái log N70 với
    By liencuongmobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 04-04-2010, 11:33
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
