AE xem cho mình cái log con x2-01 chay MxKey
MXKEY [FT SCR2000 0], SN: C0839DE4
Using device: USB ROM
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
Processing MCU file: rm709__08.70.mcusw
[BB5,XSR 1.6] size: 26.61 MB
Supported Ids: 2200050920030000, 22000509200C0000
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1A7D6778
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 0000000000CF08E8B2DF8A39B3BB69A82DE40BF3
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35974304949759_CE RT.rpl).
CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 33.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 37955B6F [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 13.656 s
Processing PPM file: rm709__08.70.ppm_t
[BB5,XSR 1.6] size: 6.80 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 3.672 s
Processing CNT file: rm709__08.70_003.image_t_ctv_ph_9g4b0
[BB5,XSR 1.6] size: 29.05 MB
Erase size: 75.31 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Programming completed in 15.406 s
Processing MMC file: rm709__08.70_sd_empty.fpsimage
[BB5,XSR 1.6] version: 0.0.0 size: 287.33 KB
Supported Ids: 22000509200C0000, 2200050920030000
No Erase header defined, erase will be skipped
Erase skipped.
Programming completed in 0.094 s
Total time for flashing process(boot+erase+write) was 46.984 s
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
Device connected: nmwcdc\Nokia X2-01 USB Phonet, PORT_ID: 23022031
Verifying communication to device OK.
Phone type: RM-709 (X2-01)
SW version: V 08.70 29-07-11 RM-709 (c) Nokia
Imei plain: 35974304949759-9
Product code: 059G4B0
Battery voltage: 3801 mV, current: 162 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00BC00000401022C00, ver: 003.006
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359743049497599
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
chạy xong vẫn bệnh cũ
