    Thành viên chính thức kieuquyen0404's Avatar
    Jun 2011
    Mặc định cần giúp 2700 khơi đông lên logo rồi treo
    2700 khơi đông lên logo rồi treo nhờ ae giúp em chay bang jaf ban đầu thì no lên dùng đươc 1 lúc lai vay đây la log cua em nó đây.JAF version 1.98.66 beta5
    Detected PKEY: 90008E4F
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.69.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-561\
    Checking path: \Products\RM-561\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_mh
    CNT Flash file: C:\Program
    Files\Nokia\Phoenix\Products\RM-561\rm561__09.98_ISM_006.image_ctv_india_marathi_b lack
    Languages in ppm: English,Hindi,Sinhalese
    Backing up CRT...
    Detected P-KEY: 90008E4F
    Init usb communication...
    Reading IMEI...
    Failed! Aborting!
    Failed to backup CRT...
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 09.07.000
    CMT RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2
    starting.......................................... .....................................Lo
    ader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 8000
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 2159, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw...
    Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
    Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
    Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
    Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
    Erasing cmt zone 00140000 - 0137FFFF ... Erase result: 0000
    Erasing cmt zone 01380000 - 0151FFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_mh...
    Erasing cmt zone 01520000 - 01DBFFFF ... Erase result: 0000
    Files\Nokia\Phoenix\Products\RM-561\rm561__09.98_ISM_006.image_ctv_india_marathi_b lack...
    Erasing cmt zone 01DC0000 - 0215FFFF ... Erase result: 0000
    Erasing cmt zone 02160000 - 03FBFFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    cmt->PAPUB keys already sent...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Rebooting...
    Finishing CMT session...
    Restarting CMT...
    Pooling phone...
    Phone not found...
    Second try...
    MCUSW: V 09.98
    06-09-10
    RM-561
    (c) Nokia
    APESW: (null)
    VariantSW: (null)
    Prodcode: 059D1B1
    Done!
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Backup full rồi thay flash đi bạn,bệnh truyền kiếp của 2700 rồi
    Moderator thanhphuek's Avatar
    Feb 2010
    Eakar Đến PLeiku
    backup rpl-pm full rồi flash fw cao nhất vẫn không được bạn xóa flash rồi flash lại nhé ,trường hợp không được thay flash rồi nạp rpl và pm full vào là done
    ĐIỆN TỬ-ĐIỆN THOẠI THANH PHÚ
    bạn kiểm tra xem mei còn đẹp không, nếu con mei thì backup full rồi chạy lại Ver cao nhất là ok. nếu không còn mei hay mei 123456612345.....thì thay cặp thôi
    Thành viên tích cực HOÀNGTRUY_GSM's Avatar
    Jan 2011
    Cần Thơ
    Tại sao báo lỗi này: FBUS INTERFACE NOT CONNECTED!!
    Còn này : Reading IMEI...
    Failed! Aborting!
    Máy info đc ko?xem coi còn imei ko?Lỗi ko backup đc do nhiều nguyên nhân
    P/S : 2700 bệnh cũng phổ biến
  6. ( HOÀNGTRUY_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    nguyenlytam (05-06-2012)
    Apr 2010
    anh lấy mx box chạy đi không hết đưa qua hwk...nếu anh như anh chạy không hết là xem lại con CPU 2 tầng nhé anh
  1. Samsung e2510 lên logo treo cần ae giúp
    By nhathuy_mobile2009 in forum Phần mềm Samsung
    Bài viết cuối: 18-03-2013, 17:35
  2. xin giúp máy sky vega a800s lên treo logo
    By pEtrAngXinh in forum Phần mềm và các mã lệnh
    Bài viết cuối: 28-12-2012, 09:29
  3. Nokia N200 khởi động lên logo treo máy xin giúp
    By dinhhien1611 in forum DCT4 - WD2
    Bài viết cuối: 21-08-2012, 22:56
  4. Cần giúp 3650W lên logo treo
    By phamhahien in forum QUALCOMM Models (3G)
    Bài viết cuối: 21-01-2012, 17:05
  5. Trả lời: 12
    Bài viết cuối: 05-01-2012, 10:30
