bác nào ngó qua em với em chạy mà nó không đồng bộ được
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0854FE1
Using device: HTI, FW ver: 00.50, SN: 00003FFC
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Processing MCU file: N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx
[BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 48.99 MB
Supported Ids: 0103192101003000, 010C192101003000
Supported Ids: 17100708
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 2261BBF4F88695D136B652E5423B3AE846C91177
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 23D000157DCD675070074EF866F7B0143720E9F8
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
Storage0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: FLASH,NAND, asic:APE
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Partitioning ...OK
Erase size: 91.38 MB
CMT FLASH,NOR area [00080000-00731951]
CMT FLASH,NOR area [00000000-0005FFFF]
CMT FLASH,NOR area [001E0000-001FFFFF]
CMT FLASH,NOR area [00880000-00FEFFFF]
erased in 42.328 s
Prog.status for Asic CMT ...
NOR: OK
NAND: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 5E8D0D50 [Rap Certificate 26 v1] sent
CMT UPDAPP block sent
CMT ADL block sent
CMT DSP0 block sent
CMT MCUSW block sent
APE KEYS block sent
APE X-LOADER block sent
APE PRIMAPP block sent
APE SOS+LOADER block sent
APE SOS*UPDAPP block sent
APE SOS+UZIP block sent
APE PAPUBKEYS: 5E8D0D50 [Ape Certificate 26 v1] sent
APE PASUBTOC block sent
APE ADL block sent
APE SOS+XZIP block sent
APE SOS*CORE block sent
APE SOS+ROFS block sent
APE SOS+ROFX block sent
Prog.status for Asic APE ...
NOR: OK
NAND: OK
Programming completed in 2 min 52.266 s
Processing PPM file: N73_rofx_4.0839.42.2.1_PRD.V08
[BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 14.70 MB
Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000
Supported Ids: 17100700, 17100701, 17100702, 17100708
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Partitioning ...OK
Erase size: 21 MB
erased in 0.312 s
NOR: OK
NAND: OK
NOR: OK
NAND: OK
Programming completed in 1 min 25.796 s
Total time for flashing process(boot+erase+write) was 5 min 17.890 s
