nhìn sườn máy im bao nhiêu write cho đúng
DINHHIEUMOBILE444 _ WELLCOM SỬA CHỮA ALL MOBILE
444 TRẢNG BOM-ĐỒNG NAI : 0909613891
Imei: 35827704802397
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C086FEA8
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 01006345
Connection status: EHCI:HUB:USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14102(15-06-2012)
Battery voltage: 4082 mV
Phone type: RM-709 (Nokia X2-01)
Product code: V 08.70
SW version: 63 - 25-03-11 - RM-709 - (c) Nokia - V
LanguagePkg version: €—
Waiting for USB device removal ...
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 00000000003548AD8847EC62F957A78CBCF5CE49
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 236B279F
Open device failed: FFFFFFFF (4) The system cannot open the file
ERROR: Failed to initialize loader, possible reason: low speed or noisy usb port (check cable) !
358277048023974_11610.rpl
358277048023974_105135.rpl
358277048023974_110422.rpl
358277048023974_115719.rpl
358277048023974_124714.rpl
5 cái này cái nào imei cũng giống. hihi
Mình write đến file thứ 5 thì có lỗi này. hjx
ấn vào restore imei và restore simlock để tự động tìm nạp imei và simlock vừa backup
lấy cáp ốp lưng hoặc cáp đa năng thử đi
Minh lúc đầu backup = ATF nên giờ ko biết rrestore trong atf ntn. hjx.
ko biet thì mang qua mx bõ mà restore
HÃY HẾT LÒNG VÌ KHÁCH HÀNG
ket qua e no' đã banh imei, có 5 file rpl mỗi file 12k, co' file PM lun rồi ma nạp hết tất cả đều banh hết trơn, trước lúc phá banh imei e có read lại hết, giờ bung ra ko biết có dc ko nhỉ
trả lời:
mình chạy flash = mx key, KQ: contrac service
xong rồi đem qua ATF write 1 file RPL, write PM. KQ: van contrac service.
e cũng ko hiểu tại sao nữa. trước lúc phá banh imei. e có réad full flash dc 1 file".BIN". bay giờ ko biết vào ATF write l ại có được ko. với e kiếm mãi ko ra cái tool nào write nó. có 2 dòng recovery trong table read flash e cũng nghịch rồi mà không được
tình hình giờ sao rồi bạn?
bạn cho xin 500 log bằng MX đê
tinh hinh e no' banh imei, write kieu gi cung ko dc. e dang rat buon!! mx key tét thì được cái này
Phone type: RM-709 (X2-01)
SW version: V 08.70 29-07-11 RM-709 (c) Nokia
Imei plain: 35827704802397-4
Product code: 059C7M5
Battery voltage: 4091 mV, current: 1 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00BC00000401022C00, ver: 003.006
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 358277048023974
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
