anh em xem hộ mình con 5130
Using device: USB ROM and HTI, FW ver: 00.50, SN: 01004029
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
Processing MCU file: rm495__07.97.mcusw
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 109001116F9D7D56002A06E473096514E0DB8924
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 28D3B054
Verifying communication to device OK.
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.625 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.625 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.016 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 1.859 s
CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 16.157 s
CMT FLASH,NOR area [01380000-0151FFFF] erased in 7.015 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 4.547 s
Processing PPM file: rm495__07.97.ppm_v
[BB5,BB5 ALGORITHM] size: 7.71 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF] erased in 35.688 s
Programming completed in 26.406 s
Processing CNT file: rm495__07.97.image_v_red
[BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 21.266 s
CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 50.328 s
Programming completed in 45.187 s
Total time for flashing process(boot+erase+write) was 8 min 9.656 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 5130 XPressMusic USB Phonet, PORT_ID: 2A56C08
Phone type: RM-495 (Nokia 5130c-2)
SW version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35422303555371-8
Battery voltage: 3645 mV, current: 111 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Market items is empty, please select the correct products path !
 LinkBack URL About LinkBacks
			 Được post bởi hiep dien thoai
