Kết quả 1 tới 10 của 11
    Thành viên tích cực mrtranquang1993's Avatar
    Mặc định lắp sim :''NHẬP MÃ HẠN CHẾ DIỆN THOẠI' cần giúp
    như tiêu đề em nhân máy khác báo vậy em cho vào ATF nạp lại file cho em nó nhưng vấn không được mxk thì em không có. bác nào có cách nào chỉ em với.thank.
    Booting Phone via FBUS...
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 3 Attempts
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 010C1921
    ID DWORD 4 : 01001101
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000232
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000353
    4 PUBLIC_ID 12
    ID DWORD 0 : 10A00003
    ID DWORD 1 : 8FE37E56
    ID DWORD 2 : 3790BB8B
    ID DWORD 3 : 895CA444
    ID DWORD 4 : 7A1BC0F2
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 191EC665
    CRC 1 : DFAAF68F
    Checksum F5
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0089 ->
    Device ID : 8981 -> NU48F256
    Extended/Fixed ID : 0000
    Revision ID : 6A21
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : 82
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21
    Flash Descriptor
    Device ID : 8981
    Revision ID : 0000
    Size : 02000000 (32 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    OLD Protocol Detected... Using Turbo Mode...
    PAPUB_KEYS_HASH_REQ_BB5
    PhoneInfoRequest_BB5 (Asic Index 00 )
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    C0E691EA16A7593A9BB28832D7312A39F7ED668D
    Scanning Simlock Applet Type...
    OK
    SL1/SL2 Applet detected
    Basic Phone Information
    MCU Version: V 07.30 07-05-09 RM-237 (c) Nokia.
    IMEI Plain : 354206038638529
    IMEI Spare : A354206038638520
    IMEI SV : 33542060386385227F
    Phone Model: Nokia 3110c
    Category : Classic Phone
    Phone Type : RM-237
    Extended Phone Information
    Product Serial Number: PBN583073
    Product Code : 0544311
    Module Code : 0203291
    Basic Production Code: 0542523
    PPM SW Version : V 07.21 05-11-08 RM-237 (c) Nokia. V
    BT MCM Version : 06cc-P9.1
    MCU SW Version : V 07.30 07-05-09 RM-237 (c) Nokia.
    HW Version : 1000
    RFIC Version : 17211721
    DSP Version : ICPR61_08w10
    AHNE Version : 11
    RETU Version : 32
    TAHVO Version : 53
    Bluetooth ID : 00:25:CF:56:43:47
    CS Type : GSM900, GSM1800, GSM1900
    Simlock Information
    CONFIG KEY : FFFFFFFFFFFFFFFF
    SP Data Corrupted....
    SIMLOCK_TYPE : PA_SL1
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Make sure you have installed the
    COMPLETE Flash Package for this Phone...
    Goto "Settings" --> "Nokia Settings" and verify that
    the Folder where you installed your Flash Files are
    in the "PRODUCT PATH TO SCAN" List...
    Thành viên chính thức hung mobille's Avatar
    cái này bác di nhờ họp mxbox thôi
    mxk rồi mang qua đây . bây giờ nhờ cúng bằng hòa.
    Thành viên kỳ cựu nguyenngocthanh19841984's Avatar
    xem con ime ko
    ime vấn nguyên bác ak.
    Feb 2012
    tây ninh
    mang qua mx box chiến ok ah.còn ko có mxbox thì dùng honda-box là ok ngay ý mà.hihi.mx box +mxcard có 680k.nên sắm 1 cái đi chú.
    cái hộp ATF chạy rồi đầu tư thế thì chế. mà ATF mới mà cúng không được hả bác.
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    atf vào mục repai simlock 1phut 30s
  9. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    mrtranquang1993 (22-12-2012)
  10. #9
    Moderator VuongKhoaMobile's Avatar
    Mar 2010
    Phone Type : RM-237
    Simlock Information
    Hạn chế điện thoại là phải rồi , ATF múc luôn đi , repair lại đi là ok . không được backup RPL lại xóa full làm lại từ đầu
  11. ( VuongKhoaMobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #10
    vâng để em làm thử coi.
  1. 2730rm-578 BỊ HẠN CHẾ ĐIỆN THOẠI
    By baotinmobile_vnn in forum BB5
    Bài viết cuối: 21-04-2013, 15:14
  2. 3110c lắp sim :''NHẬP MÃ HẠN CHẾ DIỆN THOẠI''giúp em với.
    By vboykute in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 20
    Bài viết cuối: 12-02-2011, 18:27
  3. Trả lời: 13
    Bài viết cuối: 19-03-2009, 09:24
  4. Trả lời: 15
    Bài viết cuối: 08-01-2009, 21:20
  5. Trả lời: 28
    Bài viết cuối: 30-07-2008, 23:22
