Kết quả 11 tới 20 của 20
    Thành viên tích cực sangmobilehd's Avatar
    Aug 2011
    đây là log flash em nó
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085CFC2
    Using device: HTI, FW ver: 00.50, SN: 000165B3
    Connection status: OHCI:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7601.17514
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006
    030C192101033000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 11D0000D31860F5622F1BAD66DDD24825CA3FB16
    ASIC MODE ID: 00
    ROOT KEY HASH:
    9DDBFCFE6E73CED7D8C6268C8EB85723
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
    TransmissionMode: DDR&TX2
    Processing MCU file: rm561__09.97.mcusw
    [BB5,BB5 ALGORITHM]
    Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0137FFFF]
    CMT FLASH,NOR area [01380000-0151FFFF]
    erased in 1 min 12.306 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 16.565 s
    Processing PPM file: rm561__09.97.ppm_v
    [BB5,BB5 ALGORITHM]
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF]
    erased in 27.019 s
    NOR: OK
    NOR: OK
    Programming completed in 27.268 s
    Processing CNT file: rm561__09.97.image_v_blac
    [BB5,BB5 ALGORITHM]
    page size: 128 K size: 13.64 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF]
    CMT FLASH,NOR area [02160000-03FBFFFF]
    erased in 1 min 21.308 s
    NOR: OK
    NOR: OK
    Programming completed in 47.534 s
    Total time for flashing process(boot+erase+write) was 5 min 39.302 s
    CH Sửa Chữa ĐTDĐ Anh Sáng
    Call : 0973541397 - Kinh Môn - Hải Dương
    bỏ cách ly camera xem thế nào kiểm tra áp cấp luôn
  3. #13
    Jan 2012
    bác chạy hẳn ver dụng nóc đi v9.98 xem thế nào rồi tính tiếp
    manhdung81mobile@gmail.com
  4. #14
    Thành viên tích cực BMmobile's Avatar
    Dec 2012
    nạp cho em nó ver 9.98 luôn xem sao log này chưa vào dc tesmod nhé bạn
  5. ( BMmobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    sangmobilehd (01-01-2013)
  6. #15
    Moderator CNB_DRT's Avatar
    DakLak
    Trích Được post bởi VŨ PRO Xem bài viết
    bây giờ mở máy ra chà rửa ngâm xăng cho nó 1 time đi ..sau đó sấy khô bỏ vào chạy lại thử có ok không ? nếu vẫn không được thì trả khách cho lành
    gặp mấy em như vậy rồi ,chơi game hay vào mạng thì bị chớp tắt =>trả
    nhận thay cặp chứ trả phí a !
  7. #16
    Thành viên chính thức ho nguyen gia huy's Avatar
    Trích Được post bởi BMmobile Xem bài viết
    xóa full nạp lại đi bạn ơi
    gia huy ha noi_________________________________---hhhhhhhhhhhhhhhhhhhhhhh_______________n
  8. #17
    Aug 2011
    cai này có ok ko bác .vì nếu đưa lên 9.98 rùi mà không được em đưa về lại thấp hơn dưôc579 không nhi ?
  9. #18
    Thành viên tích cực luandao_mobile's Avatar
    May 2011
    sơn la
    Trích Được post bởi sangmobilehd Xem bài viết
    đưa nên rùi lại đưa xuống thì nên làm sao đc bạn,ít nhất phải bằng ver nó chứ
    chuyên đục,phá,luộc máy khách:cool:
  10. #19
    Aug 2011
    Trích Được post bởi ho nguyen gia huy Xem bài viết
    anh giúp em tỷ mỉ nhé.em hơi gà
  11. #20
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    dòng này phải bk dc rpl & pm 120 dc mới xóa nhé
  1. 2690 sạc máy không báo gì cần giúp ngay
    By tuyen_mobile1709 in forum BB5
    Bài viết cuối: 02-10-2012, 09:49
  2. Trả lời: 1
    Bài viết cuối: 17-01-2012, 00:51
  3. 1208 cấn giúp đỡ ngay
    By ductungsl in forum DCT4 - WD2
    Bài viết cuối: 14-10-2009, 17:33
  4. cần giúp đỡ ngay n-box
    By wsxcde in forum UFSx - Nbox
    Bài viết cuối: 15-06-2009, 13:47
  5. cần giúp đỡ ngay
    By wsxcde in forum Phần mềm và các mã lệnh
    Bài viết cuối: 08-06-2009, 19:14
