Kết quả 1 tới 10 của 15
    Thành viên chính thức quan 369's Avatar
    Mặc định 1200 contac cần ae giúp
    ae em lock infor giùm,máy ban đầu hay tắt nguồn mình chạy lại thấy ok máy báo local mode tính là ok ùi ko ngờ bỏ binvao2 mở nguồn máy báo contac ae đã làm qua chỉ mình với
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 6.00
    30-09-09
    RH-99
    (c) NMP
    HW version: 2502
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    DSP version: ICPR62_08w31_UPP
    LCD version: WIN:MYKS:04
    ST7507
    PPM version: V 6.00
    30-09-09
    RH-99
    (c) NMP
    MR
    ADSP SW version: V 6.00\n30-09-09\nRH-99\n(c) NMP\nmr
    Production serial number: INL375405
    Product code: 0546971
    Module code: 0203402
    Basic production code: 0571402
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 353105029168762
    IMEI spare to net: 3A 35 01 05 92 61 78 06
    IMEI SV to net: 33 35 01 05 92 61 78 76 F2
    Master Code: 6512720374
    Failed reading simlock data...
    Phone type: RH-99, Software version: 6.00, Language Pack: MR
    User code: "!!
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
    Setting local mode...
    Reading product code...
    Product Code: 0546971
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_06.000
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_06.00mr
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai6.00mr
    Done!
    Reading...
    30-09-09
    RH-99
    (c) NMP
    HW version: 2502
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    ST7507
    PPM version: V 6.00
    30-09-09
    RH-99
    (c) NMP
    MR
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    User code: "!!
    Done!
    đường tuy ngắn không đi không đến,việc tuy nhỏ không làm không nên.yaho.quandao30
    Jan 2009
    Hải Phòng
    unlock phat lượm lúa
    Jun 2012
    có nbox hay jaf unlock phát ok
    unlock bằng jaf làm như th61 nào vạy ngọc hòa hường dẩn cho mình với
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    tic vào ô unlock rồi nhấn unlock thôi
    Thành viên tích cực luandao_mobile's Avatar
    May 2011
    sơn la
    unlock mà koheetst thì erase flash nạp lại file,viết pm lại,done
    chuyên đục,phá,luộc máy khách:cool:
    chạy lại v củ xem thế nào
    Thành viên tích cực duchung038's Avatar
    May 2011
    1200 có 2 con tụ nằm ngay conek câu lại với nhau đảm bảo ok.
    Jan 2012
    dùng jaf xóa full nạp lại>>> write pm full >>> unlock rồi dung mx đồng bộ lại ok
    đã gặp rất nhiều
    manhdung81mobile@gmail.com
    nam định
    1200 đơn giản thôi mà
    JAF xóa full nạp lại + write pm + unlock + FULL FACTORRY =DONE
    con này ko như 1202 lên jaf unlock + factorry vẫn bt
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  1. 1200 contac
    By cam binh in forum DCT4 - WD2
    Trả lời: 11
    Bài viết cuối: 21-05-2011, 08:33
  2. giúp em với 1200 Contac Service
    By ducchien in forum DCT4 - WD2
    Trả lời: 20
    Bài viết cuối: 11-09-2009, 08:54
  3. 1200 contac service cần giúp
    By cbthuanmobile in forum DCT4 - WD2
    Bài viết cuối: 04-09-2009, 15:31
  4. 1200 contac service nhờ các bác giúp
    By thutrang in forum DCT4 - WD2
    Bài viết cuối: 28-11-2008, 18:40
