Kết quả 1 tới 10 của 14
    Thành viên tích cực mrtranquang1993's Avatar
    Mặc định 200 rm-761 không nạp được file
    em có nhận cây 200 rm-761 nạp file nó báo như thế này la sao vậy các bác, chỉ giùm em với.thank
    Number of Image Files: 3
    Processing Image File :
    rm761__11.81.mcusw
    rm761__11.81.ppm_v
    rm761__11.81.image_v_059J514
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    Infineon USB Boot: F00A1FB300020303010100FF
    Sending PBL...
    PBL Successfully Sent...
    Sending SBL...
    SBL Successfully Sent...
    Setting Transmission Speed Done...
    Flash Chip Manufacturer: Intel Electronics Corp.
    Flash Boot Successful...
    Unique Data: 2F4E008A9D146000
    Original Product Code: 059J5N5
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : NPC... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\359345044917405\3593450449174 05_71424.rpl
    Data Sections : 04
    Current File : rm761__11.81.mcusw
    Compile Name: rm761__11.81.mcusw_ebl_psi.fls
    Image Type : Main Firmware
    Data Size : 26480008 Bytes
    Sending Certificate Block
    FIRMWARE Certificate Block Sent Successfully...
    Processing Section 01
    FIRMWARE Erase Block: 0x40000000~0x4001FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 131072 bytes
    Data Checksum: C1BC
    Uploading Data Blocks to phone...
    Block Write Successful...
    FIRMWARE Data Blocks uploaded to phone...
    Processing Section 02
    FIRMWARE Erase Block: 0x40040000~0x4005FFFE
    Start Erasing...
    Block Erase Done...
    Data Checksum: 7A7A
    Processing Section 03
    FIRMWARE Erase Block: 0x40060000~0x4015FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 1048576 bytes
    Data Checksum: 27B9
    Processing Section 04
    FIRMWARE Erase Block: 0x40280000~0x41A7FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 25165824 bytes
    Data Checksum: 51C5
    Processing Section 05
    FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
    Start Erasing...
    Block Erase Done...
    Data Verification Successful...
    Data Sections : 01
    Current File : rm761__11.81.ppm_v
    Compile Name: package_v.ppm_ebl_psi.fls
    Image Type : PPM Image
    Data Size : 6658928 Bytes
    PPM Certificate Block Sent Successfully...
    PPM Erase Block: 0x41A80000~0x421BFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 6655584 bytes
    Data Checksum: BF1E
    PPM Data Blocks uploaded to phone...
    Data Sections : 01
    Current File : rm761__11.81.image_v_059J514
    Compile Name: package_v_059J514.image.fls
    Image Type : CONTENT Package
    Data Size : 16387344 Bytes
    CONTENT Certificate Block Sent Successfully...
    CONTENT Erase Block: 0x421C0000~0x43E1FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 16384000 bytes
    Data Checksum: 5EAB
    CONTENT Data Blocks uploaded to phone...
    CONTENT Erase Block: 0x43E60000~0x43F3FFFE
    Start Erasing...
    Block Erase Done...
    Total Flashing Time (Erase + Flashing) : 00:04:51
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    WARNING: Phone is not in the Required Mode...
    Disconnect the Phone and Power it Up Manually.
    Scanning USB Ports...
    ERROR: Active Phone Handle was NOT DETECTED
    TIP: Make sure that Phone USB Connection Mode is
    OVI Suite Mode
    or
    PC Suite Mode
    không bác nào giúp em ak. em giờ nạp được file nhưng lên nokia rồi đơ luôn.
    rm761__10.58.mcusw
    rm761__10.58.ppm_v
    rm761__10.58.image_v_059J5S9_001
    []: Found 1 active devices.
    [Nokia USB Phonet]: Opening Connection
    [Nokia USB Phonet]: Port opened OK!
    SW: V 11.81 20-08-12 RM-761 (c) Nokia
    IMEI: 359345044917405
    START FULL PM BACKUP
    Please Wait...
    Reading : PM 0~400... OK!
    FULL PM Backup Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\359345044917405\USB_FULL_BACK UP_V 11.81 20-08-12 RM-761 (c) Nokia_359345044917405__75518.pm
    Reading Battery Value : 4112 mV
    Rebooting Phone...
    2. Insert USB.
    Sending PBL...
    Sending SBL...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\359345044917405\3593450449174 05_75526.rpl
    Data Sections : 04
    Current File : rm761__10.58.mcusw
    Compile Name: rm761__10.58.mcusw_ebl_psi.fls
    Start Erasing...
    Block Erase Done...
    Data Checksum: C1BC
    Start Erasing...
    Block Erase Done...
    Data Checksum: 7A7A
    Start Erasing...
    Block Erase Done...
    Data Checksum: F4B7
    Start Erasing...
    Block Erase Done...
    Data Checksum: 8008
    Start Erasing...
    Block Erase Done...
    Data Sections : 01
    Current File : rm761__10.58.ppm_v
    Data Size : 6437352 Bytes
    Start Erasing...
    Block Erase Done...
    Data Size: 6434008 bytes
    Data Checksum: 243B
    Data Sections : 01
    Current File : rm761__10.58.image_v_059J5S9_001
    Compile Name: package_v_059J5S9.image.fls
    Data Size : 14945552 Bytes
    Start Erasing...
    Block Erase Done...
    Data Size: 14942208 bytes
    Data Checksum: 4131
    Start Erasing...
    Block Erase Done...
    Total Flashing Time (Erase + Flashing) : 00:06:06
    Basic Phone Information
    MCU Version: V 10.58 14-12-11 RM-761 (c) Nokia
    IMEI Plain : 359345044917405
    IMEI Spare : A359345044917400
    IMEI SV : 33593450449174004F
    IMEI (2nd) : 359345044917413
    IMEI Spare : A359345044917410
    IMEI SV : 33593450449174104F
    Phone Model: Nokia 200
    Category : Entry Phone
    Phone Type : RM-761
    Extended Phone Information
    Product Serial Number: 6E2E608AH
    Product Code : 059J514
    Module Code : 0204895
    Basic Production Code: 059F7N6
    Long Production SN : 0
    PPM SW Version : V 10.58 14-12-11 RM-761 (c) Nokia V
    BT MCM Version : 19e2-47026
    MCU SW Version : V 10.58 14-12-11 RM-761 (c) Nokia
    HW Version : 1000
    RFIC Version : Dummy RFIC version
    LCD Version : AUO
    FWID Version : iV 10.58 14-12-11 RM-761 (c) Nokia V 10.58 14-12-11 RM-761 (c) Nokia V 059J514 001
    Content Pack Version : Content: v_059J5S9 V 10.58 14-12-11 RM-761 (c) Nokia
    Bluetooth ID : 04:5A:95:00:18:98
    CS Type : GSM900, GSM1800
    ********** SIMLOCK INFO **********
    CONFIG_DATA : 0010100000000000
    PROFILE_BITS : 800000000003000B
    ASIC : 11
    PROVIDER : Default Test Operator
    LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Dynamic Camera Configuration
    DCC ID : 06150123
    DCC Ver: 008027
    Status : OK
    Make sure you have installed the
    COMPLETE Flash Package for this Phone...
    Goto "Settings" --> "Nokia Settings" and verify that
    the Folder where you installed your Flash Files are
    in the "PRODUCT PATH TO SCAN" List...
    FACTORY SET TO : Full Factory Set
    OK
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    OK
    RESET LIFE TIMER TO : 0000:00
    OK
    Thành viên chính thức banhkeohaiha's Avatar
    con này flas yếu nắm ! bác mang qua phonnix muc xem ! ko dc chỉ có nước thay cặp la ok
    Nov 2012
    ĐỒNG THÁP
    load file trên navifim về đập vô em nó tỉnh ngay
    vâng để em thử coi.
    nhưng buscheck được nhưng không scan phone được,
    Nov 2012
    ĐỒNG THÁP
    máy không đồng bộ sao can được ,can được là máy sài bình thường con máy bác lỗi sao scan
    Thành viên tích cực ThùyThương_GSM's Avatar
    May 2011
    anh đóng lại flass và cpu nhé .xong rồi đem flass lại em nghĩ là tỉnh thôi vì đã làm nhiều rồi.not ok thì thay cặp anh nhé
  9. ( ThùyThương_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    mrtranquang1993 (24-01-2013)
  10. #9
    thank cac bác nhiều.
  11. #10
    V.I.P ThanhHai_GSM's Avatar
    nghiên cứu lại chỗ này đang yêu cầu bạn vào đường dẫn kiểm tra lại file
    load file thật chuẩn về flash lại
