Kết quả 1 tới 7 của 7
    Moderator thanhphuek's Avatar
    Feb 2010
    Eakar Đến PLeiku
    Mặc định 2700 cần giúp
    chào all anh em ,mình có nhận cây 2700 mở nguồn lên nokia rồi trắng màn hình một lúc sẽ tắt .Đã flash lại ok nhưng không đồng bộ được và đây là log chek nó anh em xem giúp mình nhé thanks
    LOG CHEK MXBOX
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0831550
    Using device: HTI, FW ver: 00.50, SN: 00010DCD
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 0F7001109F6D0F5624AC7014B5A7DF0165D88361
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
    TransmissionMode: DDR&TX2
    Original Imei: 35825604352787
    Original Product code: 059D1B1
    Bluetooth ID: AC81F33D9BA0
    SIMLOCK PA identifier:
    [0] PA_SL3
    còn đây là log chek ATF
    Booting Phone via FBUS...
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01033000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 0F700110
    ID DWORD 1 : 9F6D0F56
    ID DWORD 2 : 24AC7014
    ID DWORD 3 : B5A7DF01
    ID DWORD 4 : 65D88361
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum F3
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 2400 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 8A31
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : D5
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31
    Flash Descriptor
    Device ID : 2400
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    OLD Protocol Detected... Using Turbo Mode...
    PAPUB_KEYS_HASH_REQ_BB5
    PhoneInfoRequest_BB5 (Asic Index 00 )
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    Scanning Simlock Applet Type...
    OK
    PA_SL3 Applet detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    ĐIỆN TỬ-ĐIỆN THOẠI THANH PHÚ
    Feb 2010
    Eakar Đến PLeiku
    anh em vào giúp mình với nhé thanks.
    Thành viên chính thức dungmobi67's Avatar
    Oct 2011
    pak kup lại thay con lát là ok
  4. ( dungmobi67 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thanhphuek (21-03-2013)
    Nov 2010
    chắc là con flash samsung rồi
    xem có backup full được thì thay flash đi bạn
  6. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Thành viên tích cực nguoinhaque's Avatar
    Jan 2013
    em dang có 2 cây y chang vậy nè, lash sam sung mà chưa có cặp thay đây
  8. #6
    Nov 2010
    dòng 2700 này Flast yếu dể chết nhiều.
    backup full được thì thay Flast không thì thay cả cặp.
  9. #7
    Feb 2010
    Eakar Đến PLeiku
    đã ok nha anh em . backup ok => thay flash ==> flash => nạp rpl ==>pm full ===>done thanks
  1. Xin giúp em 2700
    By tuantu0103 in forum BB5
    Trả lời: 19
    Bài viết cuối: 02-01-2013, 11:29
  2. 2700 cần giúp đở
    By sonfa139 in forum BB5
    Bài viết cuối: 28-12-2011, 18:13
  3. 2700 cần giúp
    By quanlon in forum BB5
    Trả lời: 21
    Bài viết cuối: 01-08-2011, 19:12
  4. 2700 mât loa xin ae giúp đỡ
    By ducmobi_1990tq in forum BB5
    Bài viết cuối: 11-05-2011, 17:12
  5. 2700 Liệt phím xin đc giúp đỡ
    By thanhhungcb in forum DCT4 - WD2
    Bài viết cuối: 04-04-2010, 20:05
