em chưa đủ bài post đúng mục mod đừng xóa thank mod nhiều
tình trang máy quên mật khẩu chay bằng phonenix
mở nguồn chớp tắ bỏ qua mx_box flash củng zây
dây log em no ae xem dùm
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087AC06
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100E61A
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Processing MCU file: rm709__08.71.mcusw
[BB5,XSR 1.6] size: 26.61 MB
Supported Ids: 2200050920030000, 22000509200C0000
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 00000000006308B8A0BA21A15030DD179D43870F
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1C361585
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35861504098989_CE RT.rpl).
CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 33.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 37955B6F [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 16.985 s
Processing PPM file: rm709__08.71.ppm_mh1
[BB5,XSR 1.6] size: 6.98 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 5.187 s
Processing CNT file: rm709__08.71_004.image_mh1_ctv_in_v2_9l3w2
[BB5,XSR 1.6] size: 33.94 MB
Erase size: 75.31 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Programming completed in 26.937 s
Total time for flashing process(boot+erase+write) was 59.390 s
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
 LinkBack URL About LinkBacks
			 ae ai còn thức giúp em x2-01
				 tuan_vh16@yahoo.com
tuan_vh16@yahoo.com
			 Được post bởi BN Mobile™
