Kết quả 1 tới 10 của 32
    Thành viên tích cực quangtrongmobile's Avatar
    Aug 2011
    Mặc định 3110c bị contact sẻvise
    ae ạ làm wa giúp e với đây là log của nó:Version from phone: 07.30
    Version from file: 07.30
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087FD0B
    Using device: HTI, FW ver: 00.50, SN: 010106DE
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    RPL backup already exist (C:\mobileEx\3.5\data\backup\BB5_35193903087054_BA CK.rpl).
    Processing MCU file: rm237__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 2510020E02A07B56B82D11E46BF1ECBE16DC1476
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 1 min 23.453 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    NOR: OK
    Programming completed in 1 min 12.953 s
    Processing PPM file: rm237__07.30.ppm_c
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 4.62 MB
    CMT FLASH,NOR area [01080000-0151FFFF]
    erased in 24.578 s
    NOR: OK
    NOR: OK
    Programming completed in 19.109 s
    Processing CNT file: rm237__07.30.image_c_tr
    [BB5,BB5 ALGORITHM] page size: 64 K size: 3.69 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 10.75 MB
    CMT FLASH,NOR area [01520000-01FDFFFF]
    erased in 44.531 s
    NOR: OK
    Converting UCP blocks to 128 K.
    NOR: OK
    Programming completed in 16.437 s
    Total time for flashing process(boot+erase+write) was 4 min 54.984 s
    After Flash Processing ...
    Reseting Factory Values OK.
    Phone type: RM-237 (Nokia 3110c)
    SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
    Imei plain: 35193903087054-1
    Product code: 0514949
    Battery voltage: 4742 mV, current: 68 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK invalid!
    CMLA_KEY seems to be valid
    SIMLOCK_TEST failed!
    SECURITY_TEST failed!
    Imei net: 351939030870541
    Counter: 0/3, 0/10
    CONFIG_DATA: FFFFFFFFFFFFFFFF
    PROFILE_BITS: FFFFFFFFFFFFFFFF
    BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    riper simlock - riper SD sx4 wire pm 1-309 + unlock
    V.I.P Lão_Đại's Avatar
    hải phòng
    SIMLOCK invalid!
    SECURITY_TEST failed! )
    - Máy đầu tiên bị làm sao bạn , cho thêm thông tin
    Aug 2011
    e repaisimlock nó báo như thế này:MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087FD0B
    Using cached productData.
    PRIVATE ID: 941A923036F84A260473E73B3384E2EE763636E5
    Updating SIMLOCK ...error 0x1
    Reading Simlock info ...
    SIMLOCK_DATA corrupted!
    Aug 2011
    máy bật nguồn lên hiện contact sever.ko bị rơi hay rớt j cả
    Moderator nhotrung_bn's Avatar
    266-Phố Mới Thị TRấn Hồ-Thuận Thành-Bắc Ninh
    Còn cái dòng
    repair nốt đi anh thì sẽ ok
    NHOTRUNG_BN ADD: 266 Phố Mới-TTH-TT-BN
    Nhận unlock-Bẻ Khóa-Nạp Phần mềm
    Repair boot-unbrick all sam sung-sony-LG-HTC...
    Aug 2011
    repair rùi mà vẩn ko dk
    bạn có back úp ko ..banh hết rồi bgio ....write lai het di ko dc thi kt lại file xem sao nhé
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    BỘ ngoại giao trùm các 4r
    Aug 2011
    khu đèn đỏ
    Trích Được post bởi hachanyen Xem bài viết
    bạn có back úp ko ..banh hết rồi bgio ....write lai het di ko dc thi thay cặp thôi
    sl2 còn imeil thì it khi phải thay cặp
    máy đang lỗi tùm lum chủ thear cứ từ từ làm theo ý em trên not ok . lh chữ kí
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    lỗi 2 chổ đó thì sw làm là ok
    trước tiên repair simlock ->repair SD .> sx4 viết pm là ok
  1. 3110c contact sevice
    By vumobileln in forum BB5
    Trả lời: 11
    Bài viết cuối: 08-06-2010, 08:41
  2. 3110c contact service
    By THANH TRUNG in forum BB5
    Trả lời: 19
    Bài viết cuối: 04-04-2010, 18:36
  3. 3110c bao contact service
    By congtamkt in forum BB5
    Trả lời: 11
    Bài viết cuối: 20-12-2009, 22:30
  4. log 3110c contact service
    By CHHONGQUAN in forum BB5
    Bài viết cuối: 27-11-2009, 14:23
  5. 3110c contact service
    By baoth06 in forum BB5
    Bài viết cuối: 22-01-2009, 14:50
