như tiêu đề ae vào giúp với e xem trên này các anh bảo chọn 4 dòng nhưng dòng ppm1 e chọn vào nó lại k hiện file mặc dù file có đầy đủ!
log của e nó bây giờ chỉ rung trắng màn hình rồi tắt hic hic
card found: A1B5CCE8
registered to: CycloneBox
Connect phone on selected interface...
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings : FullFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm530_091.004_prd.core.fpsx
PPM2 : rm530_091.003_44.01_Vietnam_QW_prd.rofs2.fpsx
CNT : rm530_091.004_U007.000_prd.uda.fpsx
APE : rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID: 000000030000022600010007600C192102011104
CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 0910011883880344A53F7BFB3E077984A0F5AA30
ASIC MODE ID: 00
ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0
Processing RAWLOADER...
FLIC : 005000EC
Req : XSR 1.6
Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:02
Reopening the connection...
Waiting for response: 30
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 660D81A4455F6F7F9B81D5D10F5336B14B50635E
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Reading NPC certificate...
IMEI : 353784045141043
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\New folder\InfinityBox_FREE_BEST_v1.51\Backup\Cert\353 784045141043_CRT_2nd.rpl
===Flashing [MCU]===
Erase : Processing rm530_091.004_prd.core.fpsx
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing rm530_091.004_prd.core.fpsx
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [SOS+PMML]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [SOS*UPDAPP]
CMT: Writing Hash CERT [SOS*DSP0]
CMT: Writing Hash CERT [LDSP]
CMT: Writing Hash CERT [SOS*ISASW]
CMT: Writing Hash CERT [SOS+CORE]
CMT: Writing Hash CERT [SOS+ROFS1]
Total writen 707 blocks
TIME : Write time : 00:00:40
MCU Write done
ADL: Request programm status
NAND status : 00000001 / 00000001 / 00000000
===Flashing [PPM2]===
Erase : Processing rm530_091.003_44.01_Vietnam_QW_prd.rofs2.fpsx
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm530_091.003_44.01_Vietnam_QW_prd.rofs2.fpsx
CMT: Writing Hash CERT [SOS+ROFS2]
Total writen 225 blocks
TIME : Write time : 00:00:13
PPM Write done
===Flashing [CNT]===
Erase : Processing rm530_091.004_U007.000_prd.uda.fpsx
Erasing....
Erasing Ok...
Write : Processing rm530_091.004_U007.000_prd.uda.fpsx
Total writen 1 blocks
TIME : Write time : 00:00:02
CNT Write done
===Flashing [APE]===
Erase : Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx
CMT: Writing Hash CERT [SOS+ROFS3]
Total writen 2 blocks
APE Write done
ADL: Close_Session
Content: 000300000000010000000100000000
ADL: Reboot
Flashing done!
Total flash time : 00:01:02
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia E72-1
Software Info: V ICPR82_11w16.3.11 29-03-12 RM-530 (c) Nokia
IMEI: 353784045141043
Ape Version: 091.004
Product code: 0598498
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Battery voltage is enough for start
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:01:28
mod vào giúp e với huhu
down file chuẩn vào là ok
0985210545
nó k nhận dc file ppm1 là sao hả bác
Bạn thử chạy bằng phoenix xem
Bạn hiền đặt sai file rồi và thiếu file :RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx
Đặt theo thứ tự này nhé :
mcu - rm530_091.003_prd.core.fpsx
ppm1- rm530_091.003_44.01_Vietnam_QW_prd.rofs2.fpsx
ppm2- rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx
cnt1- rm530_091.003_U007.000_prd.uda.fpsx
cnt2- RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx
Còn đây là bộ file chuẩn E72 RM-530 v091.003 VIETNAM Full
nhok_jumboo89 (07-08-2014), thienmientay (07-08-2014)
e làm như lão đại bây giờ mở nguồn nó trắng màn hình rùi tắt lun, hic khách dí e quá!
nó hiện dòng đó lên báo pin k đủ nhưng e đã sạc đầy pin rồi!
Có TW quăng lên coi giúp bạn hiền nào
