Kết quả 1 tới 7 của 7
    Thành viên chính thức nguyenlaluong's Avatar
    Mặc định e71 lỗi xin giúp thank
    em nhận con e71 bật rung lên trắng 5-10s tắt nguồn luôn , em thay 2 em tavo thay cả cặp cpu flash gio chạy phần mềm nó báo như này xin giúp thank đây là check Booting Phone via FBUS...
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 3 Attempts
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 01031103
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 08D0010A
    ID DWORD 1 : 147B0052
    ID DWORD 2 : 81841EF7
    ID DWORD 3 : F955DBD9
    ID DWORD 4 : 30D26F4D
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 4B9B7510
    CRC 1 : 3E691FF8
    Checksum 27
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
    Boot File - Version 012.08.00
    Boot File - Revision 0x0002 (2)
    eBB5ProtocolType == New
    PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
    PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
    Secondary Loader Sent...
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
    Transmission Type Request Sent...
    MessageID : 06
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> not detected
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0400 -> Flash
    Device ID : 0000 -> Type not in database
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> not used
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0040 -> KAT00F00RA
    Revision ID : 0121
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.5
    Checksum : 25
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
    Algorithm File - Version 012.08.00
    Algorithm File - Revision 0x0002 (2)
    Algo Loader Sent...
    SendCodeStart_NewProtocol :
    SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok...
    VPP Enabled by Software
    Using Internal VPP
    FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
    PAPUB_KEYS_HASH_REQ_BB5
    No PAPUBKeysHash Returned
    Scanning Simlock Applet Type...
    OK
    SL1/SL2 Applet detected
    * If you want to unlock this phone, please use:
    Rebuild Simlocks via Simlock RPL
    con đây là flash bằng cáp đa năng ATF Software Version v11.70
    ATF Nitro FBUS Flash Started...
    Number of Image Files: 3
    Processing Image File :
    C:\Users\47-COMPUTER\Desktop\E71 RM-346 v510.21.009 VIETNAM Full\RM-346\rm346_510.21.009_prd.c00
    CMT Type : BB5
    CMT Algorithm : XSR 1.5
    Secondary Sending Speed : 650000 Hz
    Algorithm Sending Speed : 6500000 Hz
    Program Sending Speed : 6500000 Hz
    Message Reading Speed : 98000 Hz
    Number of Blocks : 588
    Entry Point : 0x20270D
    Page Format : 128K
    Maximum Page Size : 0x00020000
    Changing MODE : FLASH
    SET BSI Load Done
    SET BSI Load Done
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 7 Attempts
    1 SYSTEM_ASIC_ID 01
    2 EM_ASIC_ID 02
    3 EM_ASIC_ID 02
    4 PUBLIC_ID 12
    5 ASIC_MODE_ID 13
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    7 ROM_ID 15
    CRC 0 : 4B9B7510
    CRC 1 : 3E691FF8
    Checksum 27
    MessageID : 06
    SubBlocks : 06
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Index : 01
    Revision ID : 0000
    Block Length : 0B
    Device Index : 00
    Revision ID : 0121
    Block Length : 09
    Data : XSR 1.5
    Checksum : 25
    SendAlgoCode_DCT5..
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    Algo Loader Sent...
    FUR control Ok...
    Using Internal VPP
    Flash File Firmware Version cannot be Checked!
    Use VPL files to support Firmware Version Check.
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0xB1 (177)
    ERASE Blocks : 0x04 (4)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x1B (27)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    0 : 00040000-007FFFFF
    1 : 00A00000-0759FFFF
    2 : 0F1C0000-0F8BFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x00000000
    Format Info : 000000000000000B0000000000000002000000640000000300 000001000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 00000000000000090000000000000001000000640000000400 000001000000010000000000000000
    3 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000
    Erase_SendEraseBlock_BB5_NAND
    Task in Progress... Please Wait...
    Erase_SendFormatPartition_BB5_NAND
    Successfully erased..
    Time Taken to Erase : 00:00:01
    Flashing Speed: 5.00 Mhz (AUTO)
    Processing : rm346_510.21.009_prd.c00
    Total blocks to write : 588
    DDR PROTOCOL ERROR: Phone did not Ack !!! 0x01
    Flashing FAILED
    BB5_WRITE_FlashFile
    Operations Failed....
    Thành viên danh dự phongchinhphuc_pro™'s Avatar
    Feb 2008
    lâm đồng
    có thể do cặp lỗi không đồng bộ dc
    D/C: LÂM HÀ_SUCCECSS_
    AGRIBANK-NGUYỄN NGỌC PHONG
    T/K ;5404205189065
    bạn nói quá thông tin máy móc hiện tại chút coi, với log này thì 90% lỗi flash. trước tiên chọn file chuẩn hạ tốc độ flash xuống rồi flash lại xem thế nào
    Oct 2014
    bạc liêu
    tháo lash ra đo tổng trở từng chân con lash xem có mất chân nào không nhé
    liên hệ : 0907250035
    Thành viên chính thức quangminh900's Avatar
    Hà Nội
    90% là mat áp U và flash (đo áp lại đi mát áp nao câu áp đó )
    Thành viên mới congquyen's Avatar
    Lỗi No PAPUBKeysHash Returned.Trước khi Flash có Backup RPL củng như SimLock thì Restore 2 thành phần đó lại.Có thể đóng lại CPU + Flash ,kiểm tra đường mạch trên Main.Chúc bạn thành công
