Kết quả 1 tới 4 của 4
    Nov 2012
    HOA BÌNH
    Mặc định 2730 mât nguôn
    máy cheo kim 0.1a
    ae coi hộ cái lock
    Booting Phone via FBUS...
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    SET BSI Load Done
    SET BSI Load Done
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 11 Attempts
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01023000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 0F500010
    ID DWORD 1 : BEB40456
    ID DWORD 2 : 1103DB06
    ID DWORD 3 : E26A1B73
    ID DWORD 4 : FE7FF5F0
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum 3A
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 2400 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 8A31
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : D5
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31
    Flash Descriptor
    Device ID : 2400
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    PAPUB_KEYS_HASH_REQ_BB5
    ERROR: FBUS Boot FAILED
    Basic Phone Information
    Make sure you have installed the
    COMPLETE Flash Package for this Phone...
    Goto "Settings" --> "Nokia Settings" and verify that
    the Folder where you installed your Flash Files are
    in the "PRODUCT PATH TO SCAN" List...
    ĐINH VĂN TOÀN-sơn phú-cao sơn-đa bắc-hoa bình-repair boot Lumia-sky
    yahoo:dinhtoan179 lh-0979 771 345
    May 2014
    CẨM KHÊ-PHÚ THỌ
    nếu vẫn check được bình thường thì recovery lại simlock và backup imei rồi xóa full nạp lại.ko được nhà lầu thẳng tiến
    0985210545
  3. ( CAM KHE GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    dinhtoan179™ (26-06-2015)
    Nov 2012
    HOA BÌNH
    gio không back up dc imei dc
    kha năng thay nha lâu ak
    Thành viên chính thức nphoangnam's Avatar
    Mar 2008
    khó quá thì mua main khác thay vào cho xong bro ơi.hôm rồi cũng bị 1 con lên treo kim 0.1A,hết jaf rồi mxkey,cuối cùng cũng sống.
