Kết quả 1 tới 9 của 9
    HÀ GIANG GSM
    Mặc định Log N91 cần giúp;
    các bác coi dùm em cái log này voilog này vo
    Detected PKEY: 90021744
    Card life counter: 83.31%
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Booting phone...
    APE Boot Data:
    Asic ID: 17100708
    Asic Mode ID: 00
    Asic Public ID: 6A48813833A30D095266F8D2C7C0DDE2FDC57E9A
    HASH: 49A97E826B93BA20B7ED0B082475C00500000000
    ROM ID: 1DFD66132C872FD4
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101002200
    Asic Mode ID: 00
    Asic EM ID: 00000352
    Asic Public ID: 0D300013B3C7495174940C2648966ABEE694644B
    ROM ID: F28A211FCEA7B19D
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
    CMT Loader Ready
    APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg
    Loader version: 01.23.00 -> Revision: 0000
    Patching APE boot step1...
    Patching APE boot step2...
    Patching APE boot step3...
    APE Boot Ready
    APE Flash ID: 003600EC <=> SAMSUNG (SEC) -> K5E1212ACM
    APE Flash Data: 00020000000600000000000000000000
    Done!
    Restarting phone...Done!
    Fast phone flashing selected.
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V w33_07w11v1
    14-03-07
    RM-43
    (c) Nokia.
    HW version: 0600
    PCI version:
    RFIC version:  150a160e
    DSP version: nemo_w_05wk32v33b
    Retu version: 32
    Tahvo version: 52
    Production serial number: SFE952208
    Product code: 0525889
    Module code:
    Basic production code: 0525426
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 12345610654321?
    IMEI spare to net: 1A 32 54 16 60 45 23 01
    IMEI SV to net: 13 32 54 16 60 45 23 01 F0
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-43.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    CCC not available...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35839100022251_CRT_backup _153205.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\12345610654321?_CRT_backu p_155205.pm
    Done!
    Backup LCK OK!
    Done!
    Total time: 0 Minutes, 0 Seconds
    DCT4/BB5 counter: 75
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RM-43, Software version: w33_07w11v1
    IMEI: 12345610654321?
    APE Ver: (null)
    Variant Ver: (null)
    Product Code: 0525889
    Done!
    i
    Thành viên tích cực HưngMobile's Avatar
    Thốt Nốt_Cần Thơ
    Banh imeil rồi nhé bạn,liên hệ Mr Xuân mua log write vô nhé.
    HÀ GIANG GSM
    dạ em cảm on bác ;em mới vào nge chua biêt mua log a anh có thể chi cho em không ạ ?
    Thốt Nốt_Cần Thơ
    liên hệ a Xuân:lehuynhxuan@yahoo.com.Hoăc 0903303717
    Thốt Nốt_Cần Thơ
    Bạn kiểm tra lại máy tính mình xem có file .rpl backup lại không ,nếu có thì write vào đỡ tốn tiền mua log.Good luck
    HÀ GIANG GSM
    anh ơi anh co rỏ là bao nhiêu không a
    HÀ GIANG GSM
    có anh ah anh ơi chỉ dum em tùng bươc vơi a em cảm on van con
    Thốt Nốt_Cần Thơ
    click vào imeil tool ,write rpl
    HÀ GIANG GSM
    em dùng jaf
