ae forum help me 3610a RM-429. cái này của em đang xài ,khởi động nguồn lên là ó tắt luon. em chạy pm lại nhưng xài vài ngày là bị lại như cũ. ae ai có file chuẩn thì cho em xin. thank all on bro on forum. em đang chạy ver 3.56
em chạy qua cáp usb các bác ạJAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
Detected UFS_USB V2.6 (c) SarasSoft 2005. version: 01.B1, Driver version: 0, Library version: 0
USB Cable Driver version: 7.1.17.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-429\
Checking path: \Products\RM-429\
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\3610 Fold_RM-429_v1.0_sw05.53ppmV\rm429__03.53.mcusw
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\3610 Fold_RM-429_v1.0_sw05.53ppmV\rm429__03.53.ppm_v
Backing up CRT...
Detected P-KEY: 90009699
Init usb communication...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
Preparing for downgrade...
Failed to prepare for downgrade...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 07.10.000
CMT RAW loader...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ....................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 1467, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\3610 Fold_RM-429_v1.0_sw05.53ppmV\rm429__03.53.mcusw...
Erasing cmt zone 00000000 - 0001FFFF ... Erase result: 0000
Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
Erasing cmt zone 01380000 - 014FFFFF ... Erase result: 0000
Erasing cmt zone 00140000 - 0137FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\3610 Fold_RM-429_v1.0_sw05.53ppmV\rm429__03.53.ppm_v...
Erasing cmt zone 01500000 - 01BBFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
Phone not found...
DCT4/BB5 counter: 1
Done!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\3610a_RM-429_v2.0_sw03.56ppmV\rm429__03.56.mcusw
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\3610a_RM-429_v2.0_sw03.56ppmV\rm429__03.56.ppm_v
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\3610a_RM-429_v2.0_sw03.56ppmV\rm429__03.56.image_v
Backing up CRT...
Reading IMEI...
Failed! Aborting!
PRESS POWER ON NOW!
Using 06.02.002
Elf2flash 07.10.000
CMT RAW loader...
Status byte: 8000
Result: 0000
CMT blocks: 1988, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\3610a_RM-429_v2.0_sw03.56ppmV\rm429__03.56.mcusw...
Processing C:\Program Files\Nokia\Phoenix\3610a_RM-429_v2.0_sw03.56ppmV\rm429__03.56.ppm_v...
Processing C:\Program Files\Nokia\Phoenix\3610a_RM-429_v2.0_sw03.56ppmV\rm429__03.56.image_v...
Erasing cmt zone 01FC0000 - 03F9FFFF ... Erase result: 0000
Erasing cmt zone 01BC0000 - 01FBFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: V 03.56
07-10-08
RM-429
(c) Nokia
APESW: (null)
VariantSW: (null)
Prodcode: 0541446
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 9 seconds...
Done!
DCT4/BB5 counter: 1
Done! đó là cái log em chạy có gì ae giúp em thêm . thank all bro
chạy lại rồi đồng bộ nữa anh nhé. factory lại cho nó.
bản 3.56 là mới nhất rồi. nhưng bản chạy ổn định hình như là 3.53 mà nặng quá ko up được tới 55 mb
ong bạn thử đập cái này vào sau đó UI setting cho nó phát xem sao
RapidShare: 1-CLICK Web hosting - Easy Filehosting
