Kết quả 1 tới 10 của 12
    Mặc định n81 8gb vô nước xanh màn hình treo máy cần giúp
    em đã làm chân lại nguồn cpu + flash và chạy lại chương trình nhưng vẫn vậy bác nào có cách nào không giúp em với em đưa cái log chạy chương trình của nó lên các bác xem giúp em với
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-179\RM179_21.0.010_prd.C00
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-179\RM179_21.0.010_prd_0101.V01
    Languages in ppm: English,French,German,Italian,Spanish,Portuguese
    Detected P-KEY: 90013E31
    Init usb communication...
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 006.044.048
    Elf2flash 07.19.000
    CMT RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step2...
    Patching RAW boot step3...
    Sending RAW Loader...
    ....................Loader Sent!
    Stage 2 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 0600
    Selecting CMT flash...Result: 0000
    Phone is in flash mode...
    CMT blocks: 682, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-179\RM179_21.0.010_prd.C00...
    Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
    Erasing cmt zone 00083400 - 0087FFFF ... Erase result: 0000
    Erasing cmt zone 00B80000 - 05F7FFFF ... Erase result: 0000
    Partition result: 0014
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-179\RM179_21.0.010_prd_0101.V01...
    Erasing cmt zone 03730000 - 05F7FFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for ADA
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for RAP3NAND
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    cmt->PAPUB keys already sent...
    Sending CMT HASH for SOS*UPDAPP
    Sending CMT HASH for SOS*DSP0
    Sending CMT HASH for SOS*ISASW
    Sending CMT HASH for SOS*CORE
    Sending CMT HASH for SOS+ROFS
    Sending CMT HASH for SOS+ROFX
    Rebooting...
    Finishing CMT session...
    Restarting CMT...
    Pooling phone...
    Phone not found...
    Second try...
    Phone not found...
    DCT4/BB5 counter: 350
    Done!
    p/s: em chạy bằng cáp usb
    V.I.P jerrylevu's Avatar
    Jun 2005
    sài gòn
    lấy cáp đa năng chạy bằng Fbus bỏ vô jaf chạy thử mới rõ hơn . nhớ post cái log .
    Thành viên chính thức kotexsytin's Avatar
    post cai log lên,minh cũng gặp 2 con dòng BB5 rớt cạn đen màn mà chưa làm được,
    bình phước
    kiểm tra thay cáp + màn hình khác xem còn ic khiển màn nửa đâu.
    nguyên bộ màn hình dây nguồn mình đã test rồi nguồn +cpu+flash mình đã làm chân lại rồi mà vẫn vậy hà cài log ở trên là mình chạy box jaf bằng cổng usb
    Thành viên chính thức nguyenhoang_6868's Avatar
    Oct 2009
    Trời máy bị vào nước sao không bỏ ra luộc cái mên đi rùi đo điện áp cấp cho khối logic xem thế nào soa lại đóng CPU, fash, chạy phần mền làm gì vậy
    Cần hỗ trợ online Messengr nguyenhoang_6868 okN
    LUÔN LUÔN LẮNG NGHE LUÔN LUÔN CHIA SẺ
    cái này mình nghĩ nó bị thiếu một áp nguồn nào đó tương tự như áp ape của n70 vậy đó nhưng mà mình không biết câu ape của con này bác nào biết chỉ giúp mình với
    Thành viên mới trungthanhvoidienthoai's Avatar
    sao bạn vội quá vậy?máy uống nước thì bạn phải luộc đã chứ song rồi mới tính tiếp.đo áp trể kháng và tổng trcacsacs mạch nó đi đả chứ bạn
    Thành viên chính thức thienchidtdd's Avatar
    Dec 2008
    n81 8gb bi hu ic mang hinh anh em cuu dum
    Thành viên mới quocviet_mobile's Avatar
    Mặc định cac huynh de oi. em moi nhan con n81 2g cua khach. em kep dong ho nguon no dang len 2 , xin cac huyenh de chi giao
    Trích Được post bởi huuthien Xem bài viết
    các huynh đệ ơi, minh mới nhận con n81 2g của khách .. tình trạng máy kẹp đồng hồ dòng dâng lên 2,, xin các huynh đệ chỉ giáo. thak trước nhé!
  1. Trả lời: 4
    Bài viết cuối: 15-08-2013, 10:49
  2. E63 lên xanh treo xin giúp
    By tuantu_gsm in forum BB5
    Bài viết cuối: 27-03-2013, 11:22
  3. Trả lời: 0
    Bài viết cuối: 03-09-2012, 15:27
  4. e63 xanh màn hình ''treo''
    By LongBiênMobile in forum BB5
    Bài viết cuối: 31-07-2012, 19:41
  5. 2626 xanh màn hình treo máy xin giúp
    By sydungdtdd in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 27-02-2011, 17:12
