máy bạn bị như thế nào mà chạy vậy
lấy cáp khác chạy ver cao nhất .hoặc đem qua die usb chạy lại xem sao
nó rỏ 1 tý đi ,chưa gì đả đục dẻo rùi.
chuyển qua mt đập thử xem mà máy tình trạng bị gi vậy
bạn ơi bạn đọc lại từ đầu nhé mình nói rõ hết rôi đấy .
JAF version 1.98.63
Detected PKEY: 900274BA
Card life counter: 93.79%
Changing mode...Done!
Booting phone...
FAST PHONE detected!
APE Boot Data:
Asic ID: 008815D3
Asic Mode ID: 00
Asic Public ID: 5C3CDB406BC3157324BA0775AF31332818853C71
HASH: 0BBC4203E2D3B82504C75CB65E906A3500000000
ROM ID: 137A9A3B33259D2C
CMT Boot Data:
Asic ID: 000000010000022600010006400C192101031103
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 1A200114DC7100527E544E264285597E309B92AB
HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000
ROM ID: 4B9B75103E691FF8
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 88040020 <=> ST -> Type not in database
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg
Loader version: 01.23.00 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Error finding ape boot...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V ICPR72_08w41.2
25-11-08
RM-247
(c) Nokia
HW version: 1001
PCI version:
RFIC version:
DSP version:
Retu version: 15
Tahvo version: 22
Production serial number: CUC212520
Product code: 0543722
Module code:
Basic production code: 0542934
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 359320022500382
IMEI spare to net: 3A 95 23 00 22 05 30 08
IMEI SV to net: 33 95 23 00 22 05 30 08 F6
LOCK STATUS:
CONFIG KEY: 0000000000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-247.ini
Setting local mode...
Reading product code...
Product Code: 0543722
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-247\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\
Scanning ini files...
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_prd.core.fpsx
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_005.1_prd.language.fpsx
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_098.1_prd.customer.fpsx
APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_100.1_prd.uda.fpsx
Done!
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
Patching CMT loader step3...4
CMT Loader Ready
VARIANT CRT empty, skip save...
Saved to C:\Program Files\ODEON\JAF\ProgData\35932002250038_CRT_backup _9172210.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\359320022500382_CRT_backu p_9192210.pm
Done!
Backup LCK OK!
Reading SW version...ICPR72_08w41.2
Booting phone...
APE Boot Data:
Asic ID: 008815D3
Asic Mode ID: 00
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Máy bạn ấy mất áp APE đó, anh em có sơ đồ câu áp thì share cho bạn ấy với!
Trần Hoàng Thiên
Tây Nguyên Mobile - Y!M: gsmtaynguyen
cuocsongmoi (22-10-2009)
của bạn đây nhanh nhé
4shared.com - chia sẻ ảnh - tải xuống ảnh N70-N72%20trang%20man%20hinh%20cach%20%2003.jpg
còn cả đây nữa tham khảo nhé bạn
Câu áp N70, N72 giống câu áp N96 sao?![]()
Trần Hoàng Thiên
anh em ai có file tiếng việt chuẩn cho mình xin ver của mình là 12.043.thank tất cả anh em nhiều!!!
