Kết quả 1 tới 7 của 7
    Thành viên chính thức changtraigelo's Avatar
    Mặc định n70 rơi nước trắng màn treo
    JAF version 1.98.62
    Detected PKEY: 9000AAC9
    Card life counter: 99.99%
    Changing mode...Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101002200
    Asic Mode ID: 00
    Asic EM ID: 00000341
    Asic Public ID: 13600114F4C54F577CD02FBEF0107D15C6AE29F2
    ROM ID: F28A211FCEA7B19D
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v48.1
    28-08-07
    RM-84
    (c) Nokia.
    HW version: 6001
    PCI version:
    RFIC version:  150a160e
    DSP version: rolf_05wk07v29p1
    Retu version: 32
    Tahvo version: 41
    Production serial number: CIH986619
    Product code: 0524129
    Module code:
    Basic production code: 0522156
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 357927003425173
    IMEI spare to net: 3A 75 29 07 30 24 15 07
    IMEI SV to net: 33 75 29 07 30 24 15 17 F2
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini
    Setting local mode...
    Reading product code...
    Product Code: 0524129
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
    Checking path: \Products\RM-84\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: C:\mobileEx\3.2\RM-84\RM84_50737301.C0
    Phone Type:
    PPM Flash file: C:\mobileEx\3.2\RM-84\RM84_50737301.V02
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    CCC not available...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35792700342517_CRT_backup _21102411.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\357927003425173_CRT_backu p_21112411.pm
    Done!
    Backup LCK OK!
    Preparing for downgrade...
    Phone ready for downgrade!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    APE blocks present in flash file but no APE mcu detected in phone. Aborting!
    cứ chạy đến đó là dừng anh em cho em í kiến nhé vì con lày em đã câu áp theo các hình ở diễn dàn mà vẫn không được.co phai nó đang thiếu áp không các bác (APE blocks present in flash file but no APE mcu detected in phone. Aborting!
    trung tâm phá hủy mobile
    V.I.P trantamweb™'s Avatar
    Mar 2008
    Bệnh này đã nói quá nhiều rồi mà bro.Dòng N70 ,N72 rới nước trắng treo.Đừng bao giờ chạy PM.Hãy câu theo hình dưới đây nha bro.Chcus thành công
    Trantamweb : 0987.24.02.90 - 0975.19.09.90 - 0946.27.1234
    nhưng em câu theo các hình trên mà vẫn không được.vẫn trấng màn va treo.
    Thành viên mới hoalsvq's Avatar
    Nov 2010
    chú N70 của em rơi nước vệ sinh sạch sẽ sấy rồi mà vẫn trắng làm lai chân màn và ic đèn vẫn ko đc thay cả màn nữa mà ko đc có anh nào biết chỉ em mới lính mới vào nghề non tay quá ak
    Thành viên tích cực Tu0977717405's Avatar
    Dec 2009
    thanh hoa
    đóng lại chân ic cpu+flash , nghi lắm
    Dec 2009
    thanh hoa
    kô dc thi câu theo trường hợp bị trắng treo di
    Dec 2009
    thanh hoa
    cuoi cùng câu dk màn hình cho chắc ăn
  1. N91 trắng màn,treo máy
    By laothanh in forum BB5
    Bài viết cuối: 25-10-2010, 12:57
  2. N72 trắng màn hình treo máy
    By madao in forum BB5
    Bài viết cuối: 26-05-2010, 23:29
  3. n72 trắng màng hình treo
    By ox_bx in forum BB5
    Bài viết cuối: 07-12-2009, 09:46
  4. N70 Trắng màn hình treo may`!!!
    By solooo in forum BB5
    Bài viết cuối: 03-07-2009, 15:39
  5. Trả lời: 6
    Bài viết cuối: 12-09-2007, 10:06
