Kết quả 1 tới 10 của 10
    Thành viên chính thức huuphuong_9999's Avatar
    Mặc định 5130 gọi tắt nguồn nhờ ae xem hộ log
    em có nhận cây 5130 cứ gọi là bị tắt nguồn, dùng máy cấp nguồn vẫn bị vậy, em nạp lại phai khác ver cao hơn nhưng cũng không hết nhờ ae cho ý kiến, dưới dây là log em nó ae xem giúp dùm e, thanks!!!!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.91
    29-10-09
    RM-495
    (c) Nokia
    HW version: 1000
    PCI version:
    RFIC version:  06540601
    DSP version:
    ICPR72_09w33
    LCD version: SEIKO
    PPM version: V 07.91
    29-10-09
    RM-495
    (c) Nokia
    T
    BT MCM version: 2222-302
    Retu version: 16
    Tahvo version: 22
    Content Pack version: Content: t_au_red
    V 07.91
    29-10-09
    RM-495
    (c) Nokia
    Production serial number: HEE931641
    Product code: 0571957
    Module code: 0204024
    Basic production code: 0567772
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 356908035282593
    IMEI spare to net: 3A 65 09 08 53 82 52 09
    IMEI SV to net: 33 65 09 08 53 82 52 49 F7
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-495.ini
    Setting local mode...
    Reading product code...
    Product Code: 0571957
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-495\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.91.mcusw
    PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.91.ppm_v
    CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.91.image_v_red
    Languages in ppm: English,Chinese Simpl,Chinese T,Vietnamese
    Done!
    Tháo SIM gọi 112
    => Tắt nguồn thì cách li con cấp áp cho PA ( mục đích test PA có ngủm hay ko )
    Anh Minh Mobile
    32-Hoàng Diệu-Eakar-Dak Lak
  3. ( gyong ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    huuphuong_9999 (11-01-2010)
    tháo sim gọi 112 không bị tắt a ơi
    Thành viên chính thức benlucky's Avatar
    Jan 2009
    vậy bạn nên xem đường loa,chuông<khả năng là chạm ở đây>,googlucky.
  6. ( benlucky ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Thành viên chính thức dtddmatai's Avatar
    Dec 2009
    tháo cái loa trong ra là ok.hihihihihihihihihihihihihihihih
  8. #6
    Thành viên tích cực D&Dmobile's Avatar
    Feb 2010
    THIẾU LÂM TỰ
    Trích Được post bởi dtddmatai Xem bài viết
    lôi xác ướp ra làm gì vậy cu
    hỡi thế gian đâu là hạnh phúc để con thuyền bất hạnh mãi lênh đênh ??
  9. #7
    Thành viên chính thức hungphutho's Avatar
    phú thọ
    thay TAHVO mình đã làm 1 kon rùi .thay xong cho a e biết kết quả nhé
  10. #8
    Thành viên chính thức phientoai's Avatar
    ặc,đã có người bảo là sác ướp rùi còn
    em nhận tội.nhưng em không ký
  11. #9
    Thành viên mới thanhnambtr's Avatar
    Nguoi ta khong biet moi hoi sao noi loi xac uop chu
    ko spam bài đã quá cũ nhé
    Chú ý sử dụng tiếng việt có dấu
  12. #10
    Thành viên mới APTclub's Avatar
    May 2012
    Trích Được post bởi hungphutho Xem bài viết
    chu cha ơi. 5130 mà có TAHVO nữa. sư phụ luôn đó. là thành viên chính thức nữa kìa.pó tay.
    gửi chủ thớt. trước tiên bỏ sim vào và cách ly cái loa trong ra. gọi thử coi có bị tắt k nếu có thì kt tiếp. nếu k thì thay cái loa rồi dán 2 tiếp xúc loa lại. vì 5130 có tới 4 điểm tiếp xúc loa.nhớ dán 2 điểm thôi nha. dán hết là điếc luôn áh . chúc may mắn
  1. Trả lời: 10
    Bài viết cuối: 09-03-2013, 18:30
  2. 5130 rớt nước mất nguồn
    By nguyentucuong in forum BB5
    Trả lời: 16
    Bài viết cuối: 06-05-2012, 13:46
  3. 5130 mất nguồn
    By kimjunsao86 in forum BB5
    Bài viết cuối: 19-08-2011, 12:53
  4. 5130 hao nguồn gọi
    By dr556 in forum BB5
    Bài viết cuối: 13-10-2010, 14:19
  5. 5130 rớt nước mất nguồn
    By advna in forum BB5
    Bài viết cuối: 05-06-2010, 17:45
