    V.I.P ThanhHai_GSM's Avatar
    Mặc định 6233 nhờ anh em xem giúp log
    tình trạng máy bật nguồn lên chớp và trắng màn xong tắt mình chạy lai bằng hwk , mxkey đều vậy
    Version from phone: 05.43
    Version from file: 05.43
    Library version: 1.0.0.11866, Date: 26-01-2010
    RAP Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 0D400007365C025445B7986976C53E9B8D1D7BAA
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    FlashID0: 0001 002F - 0000 0121 [AMD S29NS256N,256 Mbits] type: NOR,RAP
    ExtDEVC: FFFF 0000 - 0000 0000
    RAP PAPUBKEYS HASH: 2F36DDC4990FD844712A61A80C033211BD9602E3
    Reading RAP NPC (0x168 bytes).
    Reading RAP VARIANT (0x4F0 bytes).
    Reading RAP CCC (0x0 bytes).
    Reading RAP HWC (0x0 bytes).
    Flash Imei: 35291502176081
    NPC_DATA saved OK
    VARIANT_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.3\data\backup\RPL\BB5_3529150217608 1_BACK.rpl"
    Processing file: rm123_145_30005.430.mcusw as MCU
    [BB5,BB5 ALGORITHM] size: 16.27 MB
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Total erase size: 17.75 MB
    CMT NOR area [00000000-000006BF] erased in 0.812 s
    CMT NOR area [000006C0-0000FFFF] erased in 0.109 s
    CMT NOR area [00010000-0007FFFF] erased in 2.266 s
    CMT NOR area [000A0000-0021FFFF] erased in 7.875 s
    CMT NOR area [00220000-011DDFFF] erased in 1 min 18.016 s
    CMT NOR area [011DE000-011DEFFF] erased in 0.109 s
    CMT NOR area [011DF000-011DFFFF] erased in 0.125 s
    Flash programming ...
    CMT PAPUBKEYS: 2F36DDC4990FD844712A61A80C033211BD9602E3 (Rap certificate 24 v1) written.
    Programming completed in 1 min 51.016 s
    Processing file: rm123_145_3005.43.ppm_v as PPM
    [BB5,BB5 ALGORITHM] size: 4.84 MB
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Total erase size: 5.00 MB
    CMT NOR area [011E0000-016DFFFF] erased in 25.890 s
    Programming completed in 33.188 s
    Processing file: rm123_145_30005.43.image_v_128 as CNT
    [BB5,BB5 ALGORITHM] page size: 128 K size: 3.25 MB
    NOR page size in the phone is 128 K.
    Formating FS: FILE2 ...
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Total erase size: 9.00 MB
    CMT NOR area [016E0000-01E7FFFF] erasing ...
    warning : erase sector address out of chip bound.
    Error while erasing 02 area 0x016E0000-0x01E7FFFF, Result: FFFFFFFFFFFFFF , 52
    Flashing terminated with error(s) in 15 min 50.891 s
    RX Buffer: FFFFFFFFFFFFFFD372
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    check lại cáp flash lại xem sao anh nhé.
  3. ( VŨ PRO ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ThanhHai_GSM (31-01-2010)
    Trích Được post bởi vudenproo Xem bài viết
    vẫn vậy bạn ah mình thay cáp ốp lưng khác và cáp đa năng, nâng ver cao hơn
    theo như khách bảo chỉ vào bluetooth treo máy là bị vậy
    V.I.P ThienKim GSM™'s Avatar
    Thành phố Dệt
    Con này có khả năng RAP bị hở chân nên không truy xuất được địa chỉ trên FLASH COMBO>>>>không xóa thành công được.
    Thử bóp nhẹ vào lưng RAP rồi xóa lại.Nếu NOT OK thì múc RAP ra thui
  6. ( ThienKim GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Trích Được post bởi promobile502 Xem bài viết
    Con này có khả năng RAP bị hở chân nên không truy xuất được địa chỉ trên FLASH >>>>không xóa thành công được.
    thank bạn mình cngx nghĩ vậy tạ ông khách nói nguyên nhân bệnh vậy nên phải thử cho kỹ
  8. #6
    Thành phố Dệt
    Nếu do gửi Blutouth bị như vậy thì bạn thử SKIP BT xem có chạy được không rồi hãy múc RAP
  1. Trả lời: 10
    Bài viết cuối: 28-04-2013, 12:59
  2. 6233 cần sự giúp đỡ.
    By duyquang_mobile in forum BB5
    Bài viết cuối: 24-02-2010, 15:06
  3. 6233 báo pin yếu tắt máy cần giúp......
    By dienthoaithanhan in forum BB5
    Bài viết cuối: 20-01-2010, 10:43
  4. giúp em 6233 không sạc được.
    By trunghung2008 in forum BB5
    Bài viết cuối: 01-05-2009, 20:10
  5. 6233 cần giúp đỡ
    By 070907 in forum BB5
    Trả lời: 14
    Bài viết cuối: 19-09-2008, 09:40
