Kết quả 1 tới 2 của 2
    Vi phạm nội quy truongchinhvy's Avatar
    Mặc định N70 APE blocks present in flash file but no APE mcu detected in phone. Aborting! help me
    em nhận 1 key N70 bật nguồn lên chớp chớp em đã câu dây theo mấy cách này
    rùi cho vào jaf chạy nó bào như thế này
    JAF version 1.98.66 beta5
    Detected PKEY: 9002DC7B
    Detected JAF INTERFACE version: 01.B4, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.1.29.0
    Changing mode...Done!
    Booting phone...
    Error sync the phone...
    Booting phone...
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101002200
    Asic Mode ID: 00
    Asic EM ID: 00000352
    Asic Public ID: 1310020E905E515191EDD3B2A38FE83ACD84078A
    ROM ID: F28A211FCEA7B19D
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
    Loader version: 09.2F.00 -> Revision: 0000
    Patching CMT loader step1...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    Failed! Aborting! IMEI
    Reading...
    MCU SW version: V 05wk07v47
    30-01-07
    RM-84
    (c) Nokia.
    HW version: 6061
    PCI version:
    RFIC version:  150a160f
    DSP version: rolf_05wk07v29p1
    Retu version: 32
    Tahvo version: 52
    Production serial number: CTB776456
    Product code: 0539276
    Module code:
    Basic production code: 0536420
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 359381008396435
    IMEI spare to net: 3A 95 83 01 80 93 46 03
    IMEI SV to net: 33 95 83 01 80 93 46 13 F0
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini
    Setting local mode...
    Reading product code...
    Product Code: 0539276
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
    Checking path: \Products\RM-84\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_51003301.C0
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_51003301.V02
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    các bác có cao kiến chỉ em với.thank all
    Apr 2010
    bác ơi check lại nữa xem sao nhé.flash mà bị lỗi bác làm con nguồn cái xem sao..không hết thì CPU luôn nhé..thường thì bị hay con nầy nhiều lắm..từ từ làm nhé bác..chúc bác luôn luôn thành công
  3. ( KHA_MOBILE67 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    truongchinhvy (13-08-2010)
  1. Trả lời: 0
    Bài viết cuối: 28-05-2014, 09:20
  2. Trả lời: 2
    Bài viết cuối: 08-04-2014, 22:20
  3. Trả lời: 4
    Bài viết cuối: 17-01-2011, 12:54
  4. FuriousTeam & Eason Present PACK8 - ALCATEL MTK PHONE UNLOCK TOOL V1.0.0.8
    By TuấnPhát_GSM in forum FuriouS Team Products
    Bài viết cuối: 19-06-2010, 09:37
  5. Trả lời: 4
    Bài viết cuối: 23-10-2008, 13:26
