Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 21
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    Mặc định 3110c chạy bằng MX key báo lổi
    Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
    Processing file: rm237__07.21.mcusw as MCU
    [BB5,BB5 ALGORITHM] size: 14.48 MB
    Supported RAP Ids: 0103192101001101, 010C192101001101
    RAP Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 1B7001107C837C569AB772104509C8122594C4CB
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
    ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
    TransmissionMode: 16Bit
    Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    RAP PAPUBKEYS is blank/erased.
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT NOR area [00000000-000006BF] erased in 0.922 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.172 s
    CMT NOR area [00020000-0007FFFF] erased in 1.062 s
    CMT NOR area [00080000-000DFFFF] erased in 0.187 s
    CMT NOR area [00100000-001FFFFF] erased in 0.328 s
    CMT NOR area [00200000-0031FFFF] erased in 0.375 s
    CMT NOR area [00320000-0105FFFF] erased in 3.140 s
    CMT NOR area [01060000-01067FFF] erased in 0.141 s
    CMT NOR area [01068000-0107FFFF] erased in 0.141 s
    Flash programming ...
    Error while programming [00] at 0xFFFFFFFF, Result: 0000
    Please try to use newer flashloader.
    Flashing terminated with error(s) in 42.141 s
    RX Buffer: B372
    Anh em xem hộ em cái log con này. nó vào nghe nhạc ko tìm thấy file nhạc. em đem chạy lại pm đầu tiên chạy bằng HWK thì ko chạy được, đem qua mx key thì báo lỗi thế này. hiện máy đã die. nhờ ae chỉ giúp. thanhk
    Thành viên tích cực hoangmobilephone's Avatar
    Vinh Yen
    Dùng cáp đa năng , flash = jaf bạn ơi . có gì pót lên nhá !
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    Anh đang chạy file MCU một tí là đứng phải không? Chuyển qua flash bằng dead usb đi, hoặc qua MT, cyclone... thử không được thì đục đẻo. (Con này flash bằng JAF thì được, lỗi không đồng bộ nên không lên nguồn)
    Thành viên tích cực tranhoimobile's Avatar
    Nov 2007
    Trích Được post bởi nhanvnn Xem bài viết
    RAP Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    RX Buffer: B372
    chạy bắng usb die phone xem thế nào
    Như Xuân_Thanh Hóa
    Trích Được post bởi trantukiet1008 Xem bài viết
    mình chạy đủ mọi cách rồi. vẫn bó tay ko biết nó đã chết IC flash chưa nữa
    Vinh Yen
    chưa chắc con flash đã die , nếu trên hwk mà backup đc cert , có thêm pm308 nữa thì càng tốt . ease full rùi nạp lại . sau đó restore backup
    Như Xuân_Thanh Hóa
    Detected P-KEY: 90009699
    Init usb communication...
    PRESS POWER ON NOW!
    Searching for phone...Not found!!!
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 02.33.000 RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2 starting.......................................... .......................Loader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Phone failed to boot in flash mode CMT...
    chạy bằng usb báo lỗi thế này.
    Như Xuân_Thanh Hóa
    Trích Được post bởi hoangmobilephone Xem bài viết
    em chỉ cần backup 1 309 và full rpl thôi. nhưng máy đã die rồi thì backup lên trời hả bác
    V.I.P hoanglanhpromobile's Avatar
    Jul 2008
    korea
    máy đang dùng bình thường thì không thể chết flast dc . nhìu con chạy mx báo lỗi như vậy . bạn đã có backup rpl chưa . nếu có bạn có thể xóa ful rùi check lại cáp mang wa hwk lần nữa xem sao .
    hãy nhấn nút THANKS khi bài viết hữu ích cho bạn . thank all
    Dec 2009
    rồi y chang như con bữa trước em nhận, chạy usb lúc search phone nó không nhận. Lỗi này là không vào Test mode, local mode. Cái này anh có xóa chạy lại vẫn bị y như vậy
  1. 3110c chạy báo lỗi
    By bacquandtdd123 in forum BB5
    Trả lời: 18
    Bài viết cuối: 05-01-2013, 11:52
  2. Hướng Dẫn chạy 3110c bằng hộp JAF và đường USB
    By allunlock in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 06-05-2011, 20:22
  3. Trả lời: 5
    Bài viết cuối: 28-03-2011, 21:42
  4. 3110c chạy phần mềm chết
    By hoangnammobile87 in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 34
    Bài viết cuối: 22-02-2011, 13:14
  5. Vấn đề cáp chạy cho 3110c
    By mt_gsmvn in forum BB5
    Trả lời: 11
    Bài viết cuối: 10-10-2009, 11:41
