Kết quả 1 tới 10 của 14
    Mặc định ae xem dùm mình cái log 1110
    rh70 1110 mình chạy hwk nó báo như dày nè :
    1st Boot: Ok, DCT4, UPP: 2201 [Rh-70] [2.1.0.1]
    2nd Boot: u_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
    Algorithm: u_intel.fia, Ver: 4.80.0
    Algorithm Ok, MSID: 843614889F8E4A010DCE22C11E
    Decoded MSID: 3E4EBAE9-00440FC8-A9000000
    Encoded FAID: B637063E-94593323-713F2160
    IMAGE: rh70_06.400
    Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
    Area2: 0x01010000-0x013BFFFF Erased, Time: 00:40
    Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:02
    Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
    Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
    MCU Flashing Completed, Time: 00:17
    IMAGE: rh700_nai6.40ij
    Area1: 0x01380000-0x013BFFFF Erased, Time: 00:02
    CNT Flashing Completed, Time: 00:01
    Extracting Contents Package ...
    Init Local Mode Failed
    Contents Package Extracting Failed:
    đây là log check mxkey ;
    Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011)
    ASIC ID: 0x2201 [UPP_2M ver: 2]
    SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
    Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
    FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    FlashID1: 0000 0001 [unused/removed]
    ExtBUSC: 5BDB F9A9 3792 4F75 FFDB F9A9 FFFF 5FF9
    Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
    Performing Flash Authentication ...OK
    UEM ID: 00440FC8:2984DA60
    ASIC type: 2
    UEM Imei: 35957301561354
    Flash Imei: 1D0B850ADBA3A4
    MasterCode: F685604075
    Invalid imei checksum !
    Phone not responding !
    log flash bàng mxkey:
    ExtBUSC: 5ADB F9A9 3796 5F7D FFDB F9A9 FF96 4F71
    ASIC type: 2
    Flash Imei: 1D0B84A5A251A9
    Processing MCU file: rh70_06.400
    [DCT4,DCT4 ALGORITHM] size: 1.88 MB
    Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
    ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    Area [01000000-0100FFFF] erased in 0.672 s
    Area [01010000-013BFFFF] erased in 37.641 s
    Area [013C0000-013EFFFF] erased in 2.032 s
    Area [017C0000-017EFFFF] erased in 0.110 s
    Area [01FC0000-01FEFFFF] erased in 0.110 s
    Flash programming ...
    Programming completed in 17.187 s
    File Processed in 1 min 6.141 s
    Processing CNT file: rh700_nai6.40ij
    [DCT4,DCT4 ALGORITHM] size: 154.49 KB
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Area [01380000-013BFFFF] erased in 2.547 s
    Programming completed in 1.453 s
    Content extract fail, continue anyway ...
    File Processed in 2 min 22.093 s
    Processing PPM file: rh70_06.40ij
    [DCT4,DCT4 ALGORITHM] size: 1.35 MB
    Area [011E0000-011EFFFF] erased in 0.703 s
    Area [011F0000-0137FFFF] erased in 16.125 s
    Programming completed in 12.390 s
    File Processed in 39.687 s
    Total time for flashing process(boot+erase+write) was 4 min 7.968 s
    Sóc Trăng
    xem lại U nhé bạn .
    MẩnMobile .Y/H : Jimmyphong10
    May 2010
    ĐIỆN BIÊN
    che chân số 6 đi thay cáp chắc là ok not opk thay cpu nha
    TRUNG HIẾU MOBILE
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    chuyển sang jap che chan sơ 6 (vpp) lại chắc ok liền ak
    yahoo: viethuy_mobi
    mình che chân số 6 flash đc rùi máy lên rùi , nhưng nó lại mất sóng . khởi động lên rùi lại mất
    đây là log ìno hwk :
    MCU SW : V 6.40 12-01-07 RH-70 (c) NMP
    PPM SW : V 6.40 12-01-07 RH-70 (c) NMP IJ
    Prd.Code:
    Bpr.Code:
    Prod.Sn :
    HW Vers :
    UEM : 1328
    UPP : 8705 [2201]
    RFIC Ver: 0500
    DSP Vers: P05w06.v34
    LCD Type: SDI:IOSv80 LDS162
    IMEI : 359573-01-561354-3
    SL Conf : 001-01-00000000000
    SL Prof : 000000000000000-2
    SL Var : 00003595730156135400
    SL Aux : 00020000
    HW Sig : C70C0259D9FA4148
    Box Id : 8BD1FFFFFFFFFFFF
    BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    MastCode: 66 60 10 26 60
    Provider: GSM Test Equipment
    #pw+ 956 362 775 445 576 +1#
    #pw+ 408 447 126 646 451 +2#
    #pw+ 337 546 353 567 650 +3#
    #pw+ 129 954 142 761 565 +4#
    #pw+ 313 336 634 115 045 +5#
    #pw+ 317 996 633 571 500 +6#
    #pw+ 125 854 343 310 664 +7#
    May 2010
    ĐIỆN BIÊN
    WIRITE pm chuẩn vào xem có sóng ko.not ọk xóa full flash nạp lại write pm good luck.
    TRUNG HIẾU MOBILE
    có ai co pm good ko cho mình 1 cái đi
  1. 1110 nhờ các chỉ dùm
    By LOC_PHAT_ĐAT in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 08-07-2010, 21:56
  2. 1110 bệnh lạ AE giúp dùm
    By thanhanh in forum DCT4 - WD2
    Bài viết cuối: 11-06-2009, 10:57
  3. 1110 help me!!!
    By vovan1 in forum DCT4 - WD2
    Bài viết cuối: 03-04-2008, 08:47
  4. 1110 i báo pin yếu
    By dtthuyngadp in forum DCT4 - WD2
    Bài viết cuối: 18-09-2007, 18:09
  5. SƠ ĐỒ 1110 i
    By dtthuyngadp in forum NOKIA
    Bài viết cuối: 17-09-2007, 19:23
