Kết quả 1 tới 10 của 13
    Mặc định 1208 flash cần ae giúp gấp
    1208 rơi nước vệ sinh xong không lên, chô vào bõ check ok nhưng không infor được. đây là log fash nhờ ae xem giúp. mình đã lắc cpu. nguồn.
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 260600EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh105_05.910
    Phone Type:
    PPM Flash file: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh105_05.91mr
    Phone Type:
    CNT Flash file: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh1050_nai5.91mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh105_05.910
    Booting phone...
    MCU ID: 0x2292
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x0626EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: 3a
    Loader is ready...
    MSID: 84D4771BE5D262CE9FBA73A256
    MSID decoded: 3E4EBAE90028A150A8000000
    FAID: 3D37294ADE097541714C7A7D
    Operation took 0 minutes 14 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01000000 - 0100FFFF...
    Erasing area: 01010000 - 013AFFFF...
    Erasing area: 013B0000 - 013EFFFF...
    Erasing area: 017C0000 - 017EFFFF...
    Erasing area: 01FC0000 - 01FEFFFF...
    Operation took 0 minutes 23 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh105_05.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0124FFFF...
    Erasing area: 01250000 - 0137FFFF...
    Operation took 0 minutes 7 seconds...
    Writing...
    Operation took 0 minutes 8 seconds...
    Restarting MCU...
    CNT: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh1050_nai5.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84AAE60C47244F795B611957F2
    MSID decoded: 3E4EBAE90028A150AA000000
    FAID: 12C3549DECC83D61354F23AD
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013AFFFF...
    Operation took 0 minutes 1 seconds...
    Writing...
    Restarting MCU...
    Operation took 0 minutes 0 seconds...
    Flashing Done!
    Operation took 2 minutes 10 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    V.I.P UNLOCKDTDD's Avatar
    bịt chân vpp lại múc cho nó cái xem sao
    Moderator LocPhatBacLieu™'s Avatar
    Apr 2011
    Bạc Liêu
    Máy mất nguồn thì không info được là đúng rùi bạn,
    Bạn lấy Ver cao nhất nạp cho nó 1 phát đi.
    mình đã thử bit vpp rồi vẫn thế ae ơi, du sao cung thank ae nhiều. nếu ae nào đã là qua thì cho mình xin ý kiến nhé
    Thành viên tích cực minhkhoa_iphone's Avatar
    máy mất nguồn info ko dược là phaỉ rùi,flash ver cao nhất di pồ
    Nov 2010
    xóa Full đi rồi nạp lại với ver cao nhất coi thế nào anh.che luôn cai chân VPP lại.không được thì múc UPP là vừa
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    làm như trên rùi bỏ thêm dấu tick 208 . chọn file mới . ko dc cho sang nbox múc phát >ok
    yahoo: viethuy_mobi
    May 2010
    máy rớt nước mất nguồ mà. luột lại main thật kĩ. không được nữa tháo nguồn, flat làm chân đóng lại rồi đến upp. máy rớt nước mà lỗi mềm thì chạy cái đã ok rồi chứ không báo lỗi từa lưa nữa. làm cứng cho nhanh lấy lúa, chúc thóc lúa đầy chum
    DIA_NGUC_MA
    0984745666
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    rớt nước thì sấy kĩ xong gia cố lại lần lượt ic,không được thì thay mới chạy lại
    Thành viên chính thức truyenpro0404's Avatar
    May 2011
    nạp không được nửa thì bạn thay flash rồi nạp phần mềm lại ok
    Trung tâm TM-DV viễn thông tin học AT
    Yahoo: atcomputerqn
  1. Trả lời: 5
    Bài viết cuối: 15-10-2014, 06:36
  2. Trả lời: 4
    Bài viết cuối: 19-07-2012, 15:08
  3. Flash 1208 báo lỗi
    By minhduchtp in forum DCT4 - WD2
    Bài viết cuối: 23-08-2011, 07:48
  4. 1208 xin giúp flash
    By gioidongnai in forum DCT4 - WD2
    Bài viết cuối: 29-10-2010, 11:36
  5. anh em cho xin pai flash cua 1208 voi rat can
    By lehoangky in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 18-08-2008, 07:30
