Kết quả 1 tới 7 của 7
    Thành viên tích cực vanty22's Avatar
    Aug 2011
    Mặc định ae ai rảnh giúp log e cái
    như tiêu đề ae ai rảnh giúp e cái log 1208 356045038768235 asic:b
    thank ae trước
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    đưa cái lock lên luôn đê
    Aug 2011
    Opening RPL file...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 5.91
    27-03-09
    RH-105
    (c) NMP
    HW version: 1616
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    DSP version: ICPR62_08w31_UPP
    LCD version: UNKWN: IDs:
    00:ff:00
    PPM version: V 5.91
    27-03-09
    RH-105
    (c) NMP
    MR
    ADSP SW version: V 5.91\n27-03-09\nRH-105\n(c) NMP\nmr
    Production serial number: DPQ639049
    Product code: 0588092
    Module code: 0203484
    Basic production code: 0582127
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: Opening RPL file...
    Reading...
    27-03-09
    RH-105
    (c) NMP
    HW version: 1616
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    00:ff:00
    PPM version: V 5.91
    27-03-09
    RH-105
    (c) NMP
    MR
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356045038768235
    IMEI spare to net: FA FF FF FF FF FF FF 0F
    IMEI SV to net: F3 FF FF FF FF FF FF 7F F0
    Master Code: 5013663745
    Phone type: RH-105, Software version: 5.91, Language Pack: MR
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-105.ini
    Setting local mode...
    Reading product code...
    Product Code: 0588092
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
    Checking path: \Products\RH-105\
    No ini files found...
    Done!
    e sài jaf
    Aug 2011
    khu đèn đỏ
    làm chân con flash , hoặc thay rồi flash lại xem sao a
    có hwk đưa vào mà múc cho lẹ you
    Thành viên tích cực HOÀNGTRUY_GSM's Avatar
    Jan 2011
    Cần Thơ
    buzz yahoo mình sent cho
    Feb 2011
    thanh hóa
    lấy tool làm file dct4 về mà làm
    call :0976 001 628
