Kết quả 1 tới 10 của 14
    Vi phạm nội quy huanls89's Avatar
    May 2012
    Mặc định Xem hộ em cái log này với
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C086FDF3
    Using device: HTI, FW ver: 00.50, SN: 01006B97
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
    CFI information:
    Flash settings: 0/1, size: 0x00800000
    2 Block regions:
    127 x 0x00010000 = 0x007F0000
    8 x 0x00002000 = 0x00010000
    EBL ready !
    đến đây là không check được nữa . các bác giúp em với
    https://t.me/pump_upp
    mang sang hwk chech thử rồi tung cái log nen anh em xem sao
    Hà Nội & Sài Gòn
    chọn MCU , đánh dấu tick vào xGold . rồi check .hợac Flash luôn
    May 2012
    CPU: XGOLD 110
    Sending EBL ...OK
    Boot mode: 0xCC
    CFI information:
    2 Block regions:
    EBL ready !
    Processing file: rm647_006.200
    Downloading item CODE:hw_b2_rm647_r06.200.fls, num block: 3, size: 3.99 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 37.812 s
    Erasing area 0x00C60000-0x00E4D5BE ...OK
    Programming completed in 37.203 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.156 s
    Checksum mismatch: Phone calculated 0xC88D, software calculated 0x2602
    Total time for flashing process(boot+erase+write) was 2 min 14.797 s
    Jun 2012
    chay lai luôn di chờ gì nửa ban
    May 2012
    chạy rồi nhưng báo lỗi không được anh ơi /????
    May 2012
    CPU: XGOLD 110
    Sending EBL ...OK
    Boot mode: 0xCC
    CFI information:
    2 Block regions:
    EBL ready !
    Programming completed in 39.969 s
    Programming completed in 37.360 s
    Checksum mismatch: Phone calculated 0x943D, software calculated 0x2602
    Processing file: rm647_006.20mr
    Downloading item CUST:hw_b2_rm647_006.20mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 21.328 s
    Checksum mismatch: Phone calculated 0xC515, software calculated 0xB874
    Processing file: rm6470_nai06.20mr
    Downloading item CUST:hw_b2_rm6470_nai06.20mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 5.859 s
    Checksum mismatch: Phone calculated 0xA596, software calculated 0xD819
    Total time for flashing process(boot+erase+write) was 3 min 1.812 s
    Em chạy song nó đến đây là dừng luôn
    May 2012
    có bác nào giúp Em với .
    Thành viên tích cực tuấn_mobile™'s Avatar
    Nov 2012
    Anh hùng bất khuất -???- Lạng sơn
    mang ra tiệm đi bạn !
    May 2012
    ông đọc mà không hiểu ak` ? khùng
