Kết quả 1 tới 9 của 9
    Thành viên tích cực ngoanhnga3139's Avatar
    Jul 2013
    Nghệ An
    Mặc định 1200 contact service
    Patch Aborted
    MCU SW : V 6.00 30-09-09 RH-99 (c) NMP
    PPM SW : V 6.00 30-09-09 RH-99 (c) NMP MR
    Prd.Code: 0546885
    Bpr.Code: 0566784
    Prod.Sn : IQB993762
    HW Vers : 2502
    UEM : 1328
    UPP : 8850 [2292]
    RFIC Ver: 0700
    DSP Vers: ICPR62_08w31_UPP
    LCD Type: WIN:MYKS:04 ST7507
    IMEI : 356850-02-144541-4
    SL Conf : 000-00-00000000000
    SL Prof : 000000000001000-0
    SL Var : 00003568500214454100
    SL Aux : 000B0000
    HW Sig : 0434154D5A0012FD
    Box Id : FFFFFFFFFFFFFFFF
    SL Data Corrupted
    Provider: Not Found
    IMEI: 356850-02-144541-4, ASIC: 11
    FILE: rh99_06.000
    1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.3.0.3]
    2nd Boot: u3_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
    Algorithm: u3_intel.fia, Ver: 4.80.0
    Algorithm Ok, MSID: 8457974DE3502DC5405AAC2369
    Decoded MSID: 3E4EBAE9-0098006D-AA000000
    Encoded FAID: C0995D4C-407FF992-9E435117
    Area1: 0x01140000-0x0115FFFF Erased, Time: 00:01
    PAT Flashing Completed, Time: 00:01
    SimLocks Initialized (Patch Ok), Time: 00:00
    SimLocks Initialized, Time: 00:22
    UI Defaults Ok, Time: 00:12
    Set UI Factory Defaults Ok, Time: 00:00
    Set Full Factory Defaults Ok, Time: 00:01
    Set Software Upgrade Defaults Ok, Time: 00:00
    Set Security Ok, Time: 00:00
    Prd.Code: 0546885
    Bpr.Code: 0566784
    Prod.Sn : IQB993762
    HW Vers : 2502
    UEM : 1328
    UPP : 8850 [2292]
    RFIC Ver: 0700
    SL Conf : 001-01-00000000000
    SL Prof : 800000000001000-B
    SL Aux : 000B0000
    BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    Provider: GSM Test Equipment
    Init Normal Mode Failed, no SIM Card
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    thanks đã chia sẻ mà kéo lên kéo xuống k hiểu gì lun
    Jul 2013
    Nghệ An
    hờ hờ. box hwk mà. khó hiểu thế cơ à.
    Thành viên chính thức quanghoa-mobile's Avatar
    Apr 2014
    Trích Được post bởi ngoanhnga3139 Xem bài viết
    ít ra bạn phải nói là nhận máy contact service đưa vào flat phát được luôn , chứ đâu có sửa lỗi gì đâu bạn ,
    Jul 2013
    Nghệ An
    đâu. flash nhiều mà không được đó chứ.cái này là đánh dấu tất cả vào mục UI Options rồi set vào UI Setting chờ nó set xong báo ok hết. rồi info lại. ra kết quả trên done.
    Nov 2007
    biên hòa - đồng nai
    test cái màn hình với sợi cable màn xem sao ! coi chừng chạy lộn file 1200 > 1280 kiểm tra kỹ xem sao !
    KHÔNG CÓ PAN NÀO KHÓ ! CHỈ SỢ KHÔNG " MẠNH TAY" ^_^
    YM!: phamdienmobile phone mình : 0918545113
    Jul 2013
    Nghệ An
    à. chia sẻ mà. có phải hỏi đáp đâu. hè
    Thành viên chính thức AnhTuanEmpty's Avatar
    Jun 2014
    Ninh Bình
    cái này mình nghĩ là hên sui thôi. h hết nhưng 1 2 ngày sau lại có thôi
    Jul 2013
    Nghệ An
    ko nah. cái này khắc phục đúng lỗi mà. hên xui sao được.
