Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00000000 <=> Flash -> not detected Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.10
21-01-09
RH-112
(c) NMP
HW version: 1001
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_08w31_UPP
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 03.10
21-01-09
RH-112
(c) NMP
MR
ADSP SW version: V 03.10\n21-01-09\nRH-112\n(c) NMP\nmr
Production serial number: HBH990195
Product code: 0562324
Module code: 0203762
Basic production code: 0558505
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356913031947991
IMEI spare to net: 3A 65 19 03 13 49 97 09
IMEI SV to net: 33 65 19 03 13 49 97 19 F5
Master Code: 7723751133
Phone type: RH-112, Software version: 03.10, Language Pack: MR
User code: Kulyÿ8
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Setting local mode...
Reading product code...
Product Code: 0562324
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Done!
Phone Type:
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\1202 RH-112 v.3.10\rh112_003.100
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\1202 RH-112 v.3.10\rh112_003.10el
MCU: C:\Program Files\Nokia\Phoenix\Products\1202 RH-112 v.3.10\rh112_003.100
Booting phone...
Phone didn't answer with TX line low after UEM reset!
Causes:
1. put a 27-33 pico capacitor in connector b/w mbus-gnd.
2. UEM damaged -> replace uem.
MCU ID: 0xDDDD
This MCU ID is not supported in chosen flash file...
Error booting phone...
Booting phone...
MCU ID: 0xFCBE
 LinkBack URL About LinkBacks
			 xem dùm em cái log 1202
