Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 6.40
12-01-07
RH-93
(c) NMP
HW version: 0501
PCI version:
UEM version: 2336
UPP version: 8705
RFIC version: 0500
DSP version: P05w06.v34
LCD version: INLX:MYKSv03
ST7506
PPM version: V 6.40
12-01-07
RH-93
(c) NMP
MD
ADSP SW version: no NAI version
Production serial number: VF0400516
Product code: 0529665
Module code: 0202589
Basic production code: 0520758
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 357060000307267
IMEI spare to net: 3A 75 60 00 00 03 27 06
IMEI SV to net: 33 75 60 00 00 03 27 36 F5
Master Code: 0043222106
Phone type: RH-93, Software version: 6.40, Language Pack: MD
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
Setting local mode...
Reading product code...
Product Code: 0529665
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: \Products\RH-93\
No ini files found...
Done!
Phone Type:
MCU Flash file: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.020
Phone Type:
PPM Flash file: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.02md
Phone Type:
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.020
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia
Loader size is 0x4B28; Loader chk: cb
Loader is ready...
MSID: 84E048BFE7302898DD3CD84305
MSID decoded: 3E4EBAE900020834AA000000
FAID: 323620B2462BFF7C43BF9E31
Operation took 0 minutes 7 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 33 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 12 seconds...
Restarting MCU...
PPM: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Operation took 0 minutes 8 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Operation took 0 minutes 13 seconds...
Writing...
Operation took 0 minutes 10 seconds...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 30 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-93, Software version: 7.02
IMEI: 357060000307267
Resetting PPC...
Unlocking...
ASIC: 2
SW version: 7.02
Selected flash file: d:\My Documents\Downloads\Compressed\1110i RH-93_7.02\rh93_07.020
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 01
MCU ID: 0x2201
Algo is ready...
Erasing area: 01140000 - 0115FFFF...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
MCU ID: 0x2201
Algo is ready...
Done!
DCT4 unlock counter: 9
Done!
Setting test mode...
Setting FULL FACTORY...
Done!
Operation took 0 minutes 5 seconds...
Done!
