Kết quả 1 tới 10 của 11
    Thành viên chính thức Luongmp4's Avatar
    Red face Xem hộ em cái log 2626
    em có con 2626 khách rơi nước
    Chạy nó báo như sau
    Getting MCU ID
    MCU ID: 0x3040
    FLASH ID0: 88040020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-291\
    Checking path: \Products\RM-291\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__04.61.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__04.61.ppm_ic
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__04.61.image_ic
    Languages in ppm: English,Arabic,French,Swahili
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__04.61.ppm_qa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__04.61.image_qa
    Languages in ppm: English,Chinese S,Chinese T
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__04.61.ppm_qb
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__04.61.image_qb
    Languages in ppm: English,Chinese S,Bahasa Mal
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_qb
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.image_qb
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw
    Booting phone...
    MCU ID: 0x3040
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x04882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: 11
    Loader is ready...
    MSID: 842D853FDDD74E303E062146A0
    MSID decoded: 4F16BAE900DE77FDA8000000
    FAID: 890B2123B41AF274C80065D6
    Operation took 0 minutes 12 seconds...
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01000000 - 0101FFFF...
    Erasing area: 01020000 - 018DFFFF...
    Erasing area: 01EE0000 - 01FDFFFF...
    Operation took 1 minutes 34 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 54 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.image_qb
    Booting phone...
    MCU ID: 0x3040
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84CB6716F772B71151DDF2FCDE
    MSID decoded: D26EBAF100DE77FDAA000610
    FAID: 2F96146268572BD0613D7E63
    Operation took 0 minutes 7 seconds...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01B80000 - 01EDFFFF...
    Operation took 0 minutes 33 seconds...
    Writing...
    Writing converted flash to 128k page
    Operation took 0 minutes 15 seconds...
    Restarting MCU...
    Operation took 0 minutes 1 seconds...
    Extracting Content Pack...
    Error setting local mode...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_qb
    Booting phone...
    MCU ID: 0x3040
    Boot size is 0x09A8
    Boot is ready...
    Loader size is 0x5548; Loader chk: f1
    Loader is ready...
    MSID: 845AD204F2935F698B316BD376
    MSID decoded: 3E4EBAE900DE77FDA9000000
    FAID: 783FA2532EDB227CC9758E5E
    Operation took 0 minutes 16 seconds...
    Erasing PPM...
    Erasing area: 018E0000 - 01B7FFFF...
    Operation took 0 minutes 25 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 5 minutes 32 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    là sao các anh giúp em với
    ThèmTiềnKhátTình
    Dec 2009
    GIALAI
    bỏ cái dấu rpl 208 rồi chạy lại xem sao anh
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Ok mình thử xem nào
    UI ui vẫn ko đc bạn ạ..
    mọi ngườu cho ý kiến nào
    mình dùng JAF nhé
    ThèmTiềnKhátTình
    Thành viên chính thức minhgiang_mobile's Avatar
    Jun 2010
    Kiểm Tra Lại Cable và đưa vào box khác Xóa Full nạp lại. Not ok thì Kiểm Tra Lại CPU + FLASH !
    YH : minh_giang_0108@yahoo.com.vn
    Dec 2009
    GIALAI
    xóa flash rồi tìm file khác nạp xem sao bạn. mà máy lúc đầu bị gì vậy bạn
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Trích Được post bởi HTFONE_KRONGPA Xem bài viết
    Máy rơi nước
    ThèmTiềnKhátTình
    Dec 2009
    GIALAI
    bạn đóng lại chân cpu và flash xem sao
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Mọi người đọc kĩ log dùm mình cái nhé rồi cho ý kiến .. thanks
    ThèmTiềnKhátTình
    Jun 2010
    Các ACE đã góp ý hết rồi đó, bạn chưa làm theo thì hỏi sao nửa.
    Làm theo bác này máy giờ khỏi check luôn (
    ThèmTiềnKhátTình
  1. 2626 không hộ trợ bộ sạc Cần Cứu gấp
    By thanhanh in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 05-05-2011, 18:11
  2. 2626 bệnh lạ quá đi
    By KHA_MOBILE67 in forum DCT4 - WD2
    Bài viết cuối: 26-11-2010, 08:49
  3. 2626 bệnh lạ cầu cứu anh em
    By bu0n1 in forum DCT4 - WD2
    Trả lời: 17
    Bài viết cuối: 01-05-2010, 18:10
  4. 2626
    By nguyenvu333 in forum DCT4 - WD2
    Bài viết cuối: 20-03-2010, 17:23
  5. 2626 rớt nước xạc không được
    By ngtammy in forum DCT4 - WD2
    Bài viết cuối: 20-01-2009, 01:13
