Q: What OS (operating system) are your softwares compatible ?
A: Windows XP/2k and possible soon Vista.
Q: I just got my box and i would like to install drivers. What to do ?
A: There are two drivers to install on first use. First get FG_FTDIDRIVER.rar from support, extract in one folder and after connect box to usb cable. In this moment windows will request this driver and just point him the correct directory. After get from support FG_SMARTCARDDRIVER.zip, extract in one fodler, right click on ini file and choose install. End these operations by resetting pc.
Q: I'm trying to unlock new NECs and use TREO module TXT to code features but i'm allways getting 'Error..' or 'ERROR: 00' why !?
A: First of all dongle must be upgraded with PACK 2. After kindly check and read following links:
1. http://www.furious-gold.com/blog/ind...n-furious-gold
2. http://www.furiousteam.com/blog/inde...and-680-online
Q: I just got unlock data from a TREO. How i get code ?
A: Use TREO module 'TXT TO CODE' feature and read before http://www.furiousteam.com/blog/inde...and-680-online .
Q: I just code from and LG EGOLD LITE mode but no way to enter it. What i do ?
A: Flash inside mg160bP16FL55-V10A-724-05-MAR19-2007 or kg275 AFR V10a and insert a restricted sim after flash and u'll be able to enter the code.
Q: U890 can be unlocked using 64K sim ?
A: Yes it can.
Q: I try to unlock one Blackberry and i get 'This version too old or cannot be used for unlocking'. Why ?
A: You must flash phone with firmware from support and after try code reading again.
Q: How do i enter codes in Blackberry phones ?
A: Type 'MEPPD' or 'MEPD' and after 'MEPP2' or 'MEP2'.
Q: Why do i get BAD LOGIN when i try to login support ?
A: One main possible reason is the fact you didnt activated the box.
Q: I'm using Maintainnace and i get socket errors and connection is refused . Why ?
A: Most probably reason is the fact u are using and old version.
Q: Some softs in Furious dont start or dont work properly. Why ?
A: Check if u'r dongle is updated using correct PACK or if you use latest version of the modules. Allways check forum and BETA folders.
Q: WHen i try use modules i get 'License not found !'. Why this ?
A: Use Maintainance and generate license urself.
Q: HOW TO UNLOCK U970 and U830 ?
A:
1. TO UNLOCK U970 PLEASE CONECT PHONE IN EMERGENCY MODE (2+5+PWR ON) AND CHECK 'FORCED MODE' ON SOFTWARE. AFTER FULL FLASH USING U970_UNLOCK.SEX
2. TO UNLOCK U830 PLEASE CONECT PHONE IN EMERGENCY MODE (2+5+PWR ON) . AFTER FULL FLASH USING U830_UNLOCK.SEX
Q: How do i unlock U300 and U890 (64K sims included) using FuriouS ?
A:
1. Flash using special file from support
2. Detach phone from usb cable
3. Insert orginal simcard or any sim card accepted by phone
4. Put the usb cable or charger (phone start charging)
5. Wait 10 sec then power on the phone.
6. Go in phone menu at 'unit converter' (the phone will restart)
7. Quickly remove battery, change current sim with other one (64k, 128k) and put battery back and wait.
P.S: if phone results on 'no network' then write nv file for u890 from support and
then repeat the procedure from 2 to 7.
Q: How to unlock U880 and U900 using FuriouS ?
A:
1. Flash phone using unlock/tempunlock file from support
2. Insert a restricted sim and when 'SIM LOCKED'/'USIM BLOCATA' shown on screen
press S.O.S key or type 142358#*# code blindly.
3. That's all !
Q: How i can correctly update correct PACK using MAINTAINANCE module ?
A:
1. FORMAT DONGLE
2. CHOOSE PACK YOU NEED (PACK1 OR PACK 2)
3. UPDATE FW
Q: What modules require PACK 1 written in dongle ?
A:
AMOIMOS1.exe
BenQ1.exe
BenQ2.exe
BLACKBERRY.exe
DBTELJ6.exe
DRAGON.exe
GR1000.exe
LG3G.exe
LGKE.exe
LGM1.exe
LGM2.exe
LGQ.exe
LOBSTER.exe
Lobster544.exe
MAINTAINANCE.exe
MICROSNAPPER.exe
MT.exe
NEC344.exe
NG.exe
O2x1.exe
O2x7.exe
ONDA.exe
PA.exe
PANA10X.exe
PANTECH.exe
PHILALC.exe
QFG.exe
Qualcomm.exe
QUANTA.exe
SHARP3G.exe
SIEMENSC62.exe
TOSA.exe
TREO.exe (ONLY CODE READ FOR 650)
TS21i.exe
TS605.exe
TS608.exe
VK.exe
VK3E.exe
VLE5.exe
Q: What modules can i run using PACK 2 ?
A:
NECM2.exe
TREO.exe ('TXT TO CODE' function only)
Q: I get following message when i use PHILALC module
'Signature file not found ! Re-install application.
Error ... !
Time needed - 00:00:10'. Whats wrongs ?
A: Be sure u have installed latest setup and that SEEDS.bin is near module exe.
Q: How to enter unlock codes on Blackberry phones ?
A: How to SIM Unlock the device:
1 Insert SIM into device
2 Power phone on and Turn off the radio (Turn Wireless Off option) VERY IMPORTANT.
3. Go to the "Tools" screen
4. Select "Settings"''
5. Select "Options" THEN SELECT ADVANCED OPTIONS
6. Select the "SIM Card" option
7. Type "MEPPD" (please note that you will not see what you type on the screen)
8. Type "MEPP "ALT" 2"
9. Enter the Unlock Code
10. Press enter (press on Trackball)
11 .Reboot device. Device is now unlocked
 LinkBack URL About LinkBacks
			 This is full list of the most common questions of our customer
