Kết quả 1 tới 3 của 3
    Thành viên chính thức vanthidn's Avatar
    Mặc định mấy pác cho hỏi kg800
    kG800 MÁY NƯỚC NGOÀI CÓ UNLOCK BẰNG SỐ IMEL ĐƯỢC KO VẬY MÁY PÁC XIN HƯỚNG DẨN DÙM EM ,EM CÁM ƠN NHIỀU
    Hà Nội & Sài Gòn
    1. Insert SIM . Turn on phone,
    3. On home Screen, Slide up phone,
    4. Type 2945#*#
    5. ENG. Mode menu should appear,
    6. Go Down to Factory Reset Select it, may take a few minutes to reset!
    7. This will reset the phone back to before the phone was locked to a network,
    8. The phone will automatically restart (Note the network logo at start up wont change),
    9. Now insert any SIM card (Not tested with 3 SIM) and the phone should turn on normally,
    10. The phone is now unlocked and you can customise setting as you lik
    Thành viên tích cực hoangkien822003's Avatar
    mang qua chúng tôi làm cho ,75c nguyễn du /ok
  1. Hot .hot..lg kg800
    By HUE_GSM in forum LG 3G
    Bài viết cuối: 10-10-2009, 13:47
  2. đèn bàn phím số LG KG800
    By chithang8xx in forum LG
    Bài viết cuối: 20-07-2009, 10:25
  3. LG KG800 liệt phím cảm ứng
    By Herooo in forum LG
    Bài viết cuối: 02-12-2008, 20:38
  4. cho em xin so do KG800
    By trunghung2008 in forum LG
    Bài viết cuối: 02-11-2008, 21:27
  5. Cần màn hình LG KG800
    By hagaruem in forum QUẢNG CÁO VÀ MUA BÁN
    Bài viết cuối: 06-12-2007, 09:26
